I try to cross-compile TBB
version of blackscholes (PARSEC benchmark)for Alpha ISA, butthere is an
error:
root@gem5-desktop:/home/parsec-2.1#parsecmgmt-abuild-calpha-gcc-tbb-pblackscholes
[PARSEC]Packagestobuild:blackscholes
[PARSEC][==========Buildingpackageblackscholes==========]
[PARSEC][----------Analyzingpackageblackscholes----------]
[PARSEC]blackscholesdependson:tbblib
[PARSEC][----------Analyzingpackagetbblib----------]
[PARSEC]Packagetbblibalreadyexists,proceeding.
[PARSEC][----------Buildingpackageblackscholes----------]
[PARSEC]Removingoldbuilddirectory.
[PARSEC]Copyingsourcecodeofpackageblackscholes.
[PARSEC]Running'envversion=tbb/usr/bin/make':
rm-fblackscholes
/home/alphaev67-unknown-linux-gnu/bin/alphaev67-unknown-linux-gnu-g++-O3-funroll-loops-fprefetch-loop-arrays-fpermissive-fno-exceptions-static-libgcc-Wl,--hash-style=both,--as-needed-DPARSEC_VERSION=2.1-I/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include-DTBB_VERSION-DN=960-DNCO=4blackscholes.tbb.cpp-L/usr/lib64-L/usr/lib-L/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/lib-ltbb-ldl-lrt-lpthread-oblackscholes
Infileincludedfrom/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/aligned_space.h:33,
from/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/parallel_reduce.h:33,
fromblackscholes.tbb.cpp:15:
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:91:2:error:#errorMinimalrequirementsfortbb_machine.hnotsatisfied
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'void__TBB_Pause(int32_t)':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:119:error:'__TBB_Yield'wasnotdeclaredinthisscope
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Inmemberfunction'voidtbb::internal::AtomicBackoff::pause()':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:145:error:'__TBB_Yield'wasnotdeclaredinthisscope
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'Ttbb::internal::__TBB_CompareAndSwapGeneric(volatilevoid*,T,T)[withlongunsignedintS=4ul,T=unsignedint]':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:215:error:'__TBB_CompareAndSwap4'wasnotdeclaredinthisscope
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'Ttbb::internal::__TBB_CompareAndSwapGeneric(volatilevoid*,T,T)[withlongunsignedintS=8ul,T=longunsignedint]':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:220:error:'__TBB_CompareAndSwap8'wasnotdeclaredinthisscope
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'intptr_ttbb::internal::__TBB_MaskedCompareAndSwap(volatileint32_t*,T,T)[withlongunsignedintS=1ul,T=unsignedchar]':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:200:instantiatedfromhere
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:182:error:'__TBB_CompareAndSwap4'wasnotdeclaredinthisscope
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'intptr_ttbb::internal::__TBB_MaskedCompareAndSwap(volatileint32_t*,T,T)[withlongunsignedintS=2ul,T=shortunsignedint]':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:209:instantiatedfromhere
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:Infunction'Ttbb::internal::__TBB_CompareAndSwapGeneric(volatilevoid*,T,T)[withlongunsignedintS=8ul,T=longint]':
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:525:instantiatedfromhere
/home/parsec-2.1/pkgs/libs/tbblib/inst/amd64-linux.alpha-gcc-tbb/include/tbb/tbb_machine.h:192:error:'__TBB_CompareAndSwapW'wasnotdeclaredinthisscope
make:***[blackscholes]Error1
[PARSEC]Error:'envversion=tbb/usr/bin/make'failed.
Does this mean
thatTBBdoesnotsupportalphaarchitecture?
Because
TBBrequiressomeatomicprimitiveswhichALPHAdoes
nothave,the"minialrequirements...notsatisfied"?
If I try
towritemyown__TBB_CompareAndSwap4()and
__TBB_CompareAndSwap8()forALPHAarchitecture,
andthendefiningthetwomacro""_TBB_CompareAndSwap4"and"_TBB_CompareAndSwap8",
will it
work?
- « Previous
- Next »
I add option -static-libgcc when compiling TBB, and it works. Thank you very much for your help.
- « Previous
- Next »
