Hi all,
I've just started working with the source distribution of TBB 2.1 U4 and have successfully built it using the /MT flag instead of /MD - no problems yet. However, I noticed that the build does not embed the manifest in the DLL (windows platform). I would like to add a change request to the have the build process automatically embed the manifest.
Peter
Peter
Quoting - pvonkaenel
Hi all,
Peter
Peter
Never mind, I think there was no manifest due to my conversion to /MD. I believe I have it straightened out now.
Peter
Peter
I have a follow-on question relating to this. When I build with the standard /MD a manifest file is generated from the "created" tbbmanifest.c file. When I build with /MT that manifest is not created and I have to comment it out of the resource file to get the build to work. It looks like I can still use the tbb.dll file eventhough it has no embedded manifest. My quesion is, how is this possible? Are manifests only required for modules that have dependencies that themselves have manifests?
Peter
Peter
My understanding is that when you use /MD switch manifest contains dependencies from VC runtime. When you use /MT switch you does not depend on any VC runtime because you linked statically with it. Why do you need a manifest in this case?
Vladimir
Quoting - Vladimir Polin (Intel)
Vladimir
Thanks for responding. I think the answer is "I don't". I've been running with the manifest-free DLL for quite a while now without problems. If a manifest was required, then application loading would fail (which it has not).
Thanks again,
Peter
The development downloads (tbb21_20090511oss for example) embed the manifests. It would be great if the stable release source provided a make option for this. We need the manifests to be embedded when the dll are loaded by a java app. So are project has been "camped" on the development releases, and would prefer not having to modify a stable release download.
Quoting - William Case (Intel)
TBB 2.1 updates and so corresponding commercial-aligned OSS releases do embed MSVCRT manifests.
Topic Options
