2485 Discussions
Enhancement Request: Parallel for/do order when limited to a single thread
Alex_N_Intel
I would like to request an enhancement of TBB loop patterns: if the Task Scheduler is limited to a single thread, the behavior of parallel for/do/other loops should be sequential and completely backward compatible to a single-thread execution.
Motivation: we are moving legacy single-threaded code to parallel execution, we need to keep backward compatibility. Users that do not choose to use the new parallel features should experience no behavior change.
As for now, I have to maintain 2 code streams: parallel and single-threaded. This complicates the development and the result code.
It seems that enabling backward compatibility for a single thread is not complicated and will not add performance overhead for TBB parallel loops.
Thanks!
Alex Nikonov
RafSchietekat
Valued Contributor III
Could you specify the observed differences and why they matter?
