I have create several threads in my parallel program, unfortanetly each thread need write and read some files in the disks, which will cause i/o competition.
Now, I want to statistcs the total I/O time, and I use the following code:
this read code is:
this write code is:
readTime and writeTime is two global parameters.
Total time of my program is statistcsed by the tick_count of tbb
The following is the time statistcs results of my programm, and I have use 1 and 4 threads.
1 thread:
Total time 459152 ms
Read time 16209.7ms
Write time 67889.2ms
4 thread:
Total time 197372ms
Read time 18958.2ms
Write time 234602ms
To 4 thread, the sum of read and write time is larger than the total time, its impossible.
I have thought that maybe I sould add the lock to the readTime and writeTime, so I use the spin_rw_mutex to protect these
two parameters. But the result is the same.
So, what mistake i have made? and Is there any good method to do it correctly.
Please do me a favour!
Thank you very much!
chu qiu
this read code is:
[cpp]struct timeval tvafter,tvpre;
struct timezone tz;
gettimeofday (&tvpre , &tz);
//Write to the disk
store->Write(node->Path().Page(), buf);
gettimeofday (&tvafter , &tz);
writeTime += (tvafter.tv_sec - tvpre.tv_sec) * 1000 + (double)(tvafter.tv_usec - tvpre.tv_usec)/1000.0;[/cpp]
this write code is:
struct timezone tz;
//Write to the disk
store->Read(node->Path().Page(), buf);
readTime += (tvafter.tv_sec - tvpre.tv_sec) * 1000 + (double)(tvafter.tv_usec - tvpre.tv_usec)/1000.0;[/cpp]
1 thread:
Read time 16209.7ms
4 thread:
Total time 197372ms
Read time 18958.2ms
Write time 234602ms
chu qiu
To avoid mishaps because of subtractingtwo unsigned integers (timeval::tv_usec), you could use tbb::tick_count instead, thereby also making this a valid TBB-related question. :-)
Quoting - chqiu@cuc.edu.cn
4 thread:
Total time 197372ms
Read time 18958.2ms
Write time 234602ms
Total time 197372ms
Read time 18958.2ms
Write time 234602ms
4 threads are able to execute up to 788 seconds of reads/writes in 197 seconds of real time. And in your case they execute only 253 seconds of reads/writes. So I do not see anything strange in your numbers.
Sorry, I was too quick on the draw again: #0 did mention tick_count (but then why not use it also for read and write?), and tv_usec's type is signed all right (I was confusing type with value normalisation if using timeval as the result). readTime and writeTime should really be protected by a mutex, however (unless they're atomic).
Quoting - Raf Schietekat
Thank you for your reply!
the realTime and writeTime is double, and I think they're computed correctly, because the total time is computed with the same method.
Furthermore, I have use tick_count to get the total time of my program, its result is the same as my method.
I'll try you suggestion.
Quoting - Dmitriy Vyukov
197 seconds is the total time of my program running with 4 threads, not the time of one thread
thank you very much!
