Error with TBB library during compilation -ltbb
Dave_O_
I am having the probelm
ld error with -ltbb.
I have the new update sp1.1.106 of icc. when I run icc main.c -tbb I get the error. What do I do?
Vladimir_P_1234567890
hello Dave,
what is OS, gcc version and target architecture?
--Vladimir
Dave_O_
OS = CentOS
Compiler =  ICC 14.0.1.106 Build 20131008
Target: E5-2670 and Xeon Phi
Thank you
I assume you build for offload execution.
Which shell do you use? is it bash?
--Vladimir
jiri
Note that this is also being investigated in the MIC forum, which may give some more information about this issue and possibly some other issues related to this.
http://software.intel.com/en-us/forums/topic/484891
