Floating Point Exception from concurrent_vector
renorm
I am getting underflow exception in release more, but not in debug mode. This is what causing the error:
[cpp]#include
unsigned int fp_control_state = _controlfp(_EM_INEXACT, _MCW_EM);
struct Element
    std::vector data;
    double x, y;
tbb::concurrent_vector v;
// this fails with FP exception
Element& e = *v.push_back(Element());
// stepping inside with the debugger leads to the line 890 in concurent_vector.h
void init(const void *src) { for(; i < n; ++i) new( &array ) T(*static_cast(src)); }
[/cpp]
My platform is WinXP 32, Visual Studio 2008, tbb30_104oss with binaries downloaded from TBB website.
Andrey_Marochko
New Contributor III
Does this happen in a single threaded mode, or the application uses other TBB constructs too?
Andrey_Marochko
New Contributor III
Upon the second thought, the exception may happen because of copying garbage in Element::x and Element::y members.
renorm
Looks like it is because of copying garbage. Default constructor which sets structure fields to 0 fixed the problem.
