Flow Graph - target_node?
ronag89
Given the following example which requires a busy loop:
tbb::flow::graph g;
tbb::flow::function<int, int, tbb::flow::rejecting> n0(g, body());
tbb::flow::function<int, int, tbb::flow::rejecting> n1(g, body());
tbb::flow::make_edge(n0, n1);
// Thread 1 - Read from file
while (!eof)
   n0.try_put(read_int());
// Thread 2 - Write to file
while (true)
    int value;
    while(n1.try_get(value))
        if (value == -1)
          return;
        write_int(value);
    sleep(20);
I haven't been able figure out any pattern which allows me to get around the busy loop.
The only thing I can think of is a "target_node" with similar semantics to "concurrent_bounded_queue".
i.e.
target_node<int> t;
tbb::flow::make_edge(n1, t);
while (true)
   int value;
    t.pop(value);
    if (value == -1)
       return;
    write_int(value);
I've tried to implement "target_node" myself. Although I am not 100% sure it is correct.
template<typename T>
struct target_node
	: public tbb::flow::receiver<T>
	, boost::noncopyable
	tbb::spin_mutex					predecessors_mutex_;
	std::list<predecessor_type*>	predecessors_;
	boost::condition_variable		cond_;
	boost::mutex					mutex_;
	std::queue<input_type>			queue_;
	std::size_t						capacity_;
	target_node(std::size_t capacity = std::numeric_limits<std::size_t>::max())
		: capacity_(capacity)
	tbb::task* try_put_task(const input_type& v) override
			boost::lock_guard<boost::mutex> lock(mutex_);
			if (queue_.size() >= capacity_)
				return nullptr;
			queue_.push(v);
		cond_.notify_one();
		return tbb::flow::interface7::SUCCESSFULLY_ENQUEUED;
	bool register_predecessor(predecessor_type& p)  override
			tbb::spin_mutex::scoped_lock lock(predecessors_mutex_);
			predecessors_.push_back(&p);
		cond_.notify_one();
		return true;
	bool remove_predecessor(predecessor_type& p) override
			predecessors_.erase(std::find(predecessors_.begin(), predecessors_.end(), &p));
		return true;
	void pop(input_type& value)
		boost::unique_lock<boost::mutex> lock(mutex_);
		while (true)
			if (!queue_.empty())
				value = std::move(queue_.front());
				queue_.pop();
				return;
				for (auto p : predecessors_)
					if (p->try_get(value))
						return;
					if (p->register_successor(*this))
						remove_predecessor(*p);
			cond_.wait(lock);
	void reset_receiver()
		value_.reset();
Does this make sense? Am I missing something? Is there a better way?
