parallel_task(IsThreadNumber$ + OpenGLthreadNumber, aFun, arg1, arg2); // with or without args
Where OpenGLthreadNumber is the thread number you desire.
intptr_t OpenGLthreadNumber = -1; // global scope
// after thread pool init, as main thread
OpenGLthreadNumber = qt_get_thread_num();
Some versions of OpenGL requires the process main thread to open the handle to GL, other versions do not.
You will have to decide as to if you want to use or not use the main thread for OpenGL.
Jim Dempsey
the OpenGL context, I get errors from the drivers implementations...
I think some kind of binding based on indexing could be used ( below is a pseudo-code / sorry, I didn't try it to execute ):
class CMyTask : public tbb::task
public :
CMyTask( void ) { ... };
CMyTask( int iNumber )
m_iNumber = iNumber;
~CMyTask( void ){ ... };
tbb::task * execute()
if( m_iNumber == 1 )
...do task 1...
else
if( m_iNumber == 2 )
...do task 2...
return ( tbb::task * )NULL;
private:
int m_iNumber;
I agree that it doesn't look good but if it works and allows to do what you want why not?
By the way, I use a similar trick with OpenMP when I need to "bind" some processing to some OpenMP thread.
Sergey
