This should be happening with almost any GCC 6 version for the last year.
The following fragment has issues:
111 public: 112 static generic_scheduler* allocate_scheduler( market& m ) { 113 void* p = NFS_Allocate(1, sizeof(scheduler_type), NULL); 114 std::memset(p, 0, sizeof(scheduler_type)); 115 scheduler_type* s = new( p ) scheduler_type( m ); 116 s->assert_task_pool_valid(); 117 ITT_SYNC_CREATE(s, SyncType_Scheduler, SyncObj_TaskPoolSpinning); 118 return s; 119 }
Here std::memset is optimised away because marked as dead. This happens because according to C++ standard it does not effect objects life-time. The problem here is that TBB classes (e.g., generic_scheduler and scheduler) does not contain default values. There are a few things that on compiler side resolves the issue, e.g. -fno-builtin-memset (will force GCC not to optimise away memset), -flifetime-dse=1 or -fno-lifetime-dse. But this is an issue within TBB, thus better to fix it in the code.
GCC bugzilla item: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=71388
Thanks for the information David.
We will add a workaround with -flifetime-dse=1 to our makefiles, and later we'll see if the issue should be addressed in a different way. To be honest, I am not sure if anything else should be done though. Constructing an object in a zero-initialized memory seems a perfectly fine technique to me, and removal of pre-lifetime stores is questionable. In particular, the standard says in 3.8/5 that it's OK to use the obtained address as void*, and neither of the cases of undefined behavior described there seemingly apply. In particular, the code does not interpret the address as a valid pointer to an object, and does not access non-static data members (i.e. I do not think that filling the memory counts as such). So I tend to think that using memset before running an in-place constructor is OK from the C++ standard viewpoint, and so GCC should have not thrown it away without even giving a warning.
