I'm using TBB via the latest vcpkg. Compiling under VS2019, x64-windows-static debug.
I get the following error
tbb_debug.lib(tbb_main.obj) : error LNK2005: DllMain already defined in tbbmalloc_debug.lib(tbbmalloc.obj)
Any idea how that I can fix this? Now I'm building with /FORCE:MULTIPLE to make it succeed.
Can a program link with both (tbb_debug and tbbmalloc_debug) libs, or should only one lib be used?
I'm using tbb/scalable_allocator.h and tbb/concurrent_queue.h only.
Could you please provide us a sample reproducer code along with the steps to reproduce the issue?
Could you also provide the version of TBB you are using?
Thanks & Regards,
Santosh
We haven't heard back from you. Could you please provide us a sample reproducer code along with the steps to reproduce the issue? Could you also provide the version of TBB you are using?
Thanks & Regards,
Santosh
Sorry, I'm very busy at the moment. I will look at it later. Merci!
Sure, you can take your own time to get back to us.
Whenever it is possible for you to provide a sample reproducer, feel free to post a new question. We would be more than happy to help you there. For the time being, could you please let us know whether we can close this thread?
Thanks & Regards,
Santosh
Hi Santosh,
Yes you may close this thread. I will post a new question if I can create a sample reproducer.
Bert
We are closing this thread for now. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
