2466 Discussions
Having issues compiling code of A Parallel Stable Sort Using C++11 TBB
Shlok_P_
Intel has already provided the source code for this. But I assume there is some issue with code in the file named "test.cpp" at line number 276 where it says.Severity Code Description Project File Line Suppression State  -> Error name followed by "::" must be a class or namespace name
Here is the link to get the source code
https://software.intel.com/en-us/articles/a-parallel-stable-sort-using-c...
Can anyone help me fix this issue?
Thank You in advance
Alexei_K_Intel
Hi Shlok,
Could you share the compiler version and the full output related to the observed error, please? In addition, you may want to consider the similar question: https://software.intel.com/en-us/forums/intel-threading-building-blocks/topic/706027.
Alex
Shlok_P_
Thank You Alex for your reply
I am using compiler - Intel Compiler 16.0(Under the Intel Parallel Studio XE 2016 product group) 2016 in IDE Microsoft Visual Studio 2015 Community
full output related to the observed error -
Error (active) name followed by '::' must be a class or namespace name Gpu621 c:\Users\SP\Documents\Visual Studio 2015\Projects\Gpu621\Gpu621\test.cpp 276
 pss::parallel_stable_sort( i, i+n, KeyCompare(KeyCompare::Live) ); // THIS IS THE line in which I am getting error and the highlighted part is pss
I hope this is what you are asking for.
Thank You really appreciate it
Alexei_K_Intel
The provided example does not have Visual Studio project file to be built. Do you define the threading engine that should be used by the test? The makefile uses the compiler switch "-D" to define one of the four macros to enable particular threading. Try to add one of the following macro definitions at the beginning  of test.cpp:
#define USE_CILKPLUS 1
#define USE_TBB_LOWLEVEL 1
#define USE_TBB_HIGHLEVEL 1
#define USE_OPENMP 1
Pay attention that you need only one macro definition.
Alex
