Intel has already provided the source code for this. But I assume there is some issue with code in the file named "test.cpp" at line number 276 where it says.Severity Code Description Project File Line Suppression State -> Error name followed by "::" must be a class or namespace name
Here is the link to get the source code
https://software.intel.com/en-us/articles/a-parallel-stable-sort-using-c...
Can anyone help me fix this issue?
Thank You in advance
Hi Shlok,
Could you share the compiler version and the full output related to the observed error, please? In addition, you may want to consider the similar question: https://software.intel.com/en-us/forums/intel-threading-building-blocks/topic/706027.
Alex
Thank You Alex for your reply
I am using compiler - Intel Compiler 16.0(Under the Intel Parallel Studio XE 2016 product group) 2016 in IDE Microsoft Visual Studio 2015 Community
full output related to the observed error -
pss::parallel_stable_sort( i, i+n, KeyCompare(KeyCompare::Live) ); // THIS IS THE line in which I am getting error and the highlighted part is pss
I hope this is what you are asking for.
Thank You really appreciate it
The provided example does not have Visual Studio project file to be built. Do you define the threading engine that should be used by the test? The makefile uses the compiler switch "-D" to define one of the four macros to enable particular threading. Try to add one of the following macro definitions at the beginning of test.cpp:
#define USE_CILKPLUS 1 #define USE_TBB_LOWLEVEL 1 #define USE_TBB_HIGHLEVEL 1 #define USE_OPENMP 1
Pay attention that you need only one macro definition.
Alex
