Hi all, I installed tbb on my system recently, but when I compile a program in VS2005 which has nothing to be with tbb, building is ok, when clicking the xx.exe, error will ocurr
"tbb.dll is not a valid image",
then I cleared tbb related thing from the system, I got
"This application has failed to start because tbb.dll was not found.Re-installing the application may fix this problem."
Could you help me out? Thanks!
This has something to do with your application could not findthe microsoft visual C++ runtime library in your system. Make sure all the ms redistributable dll's path is included in your PATH environment variable.
Long
