Help with Fibonacci Recursive
Gregory_G_
Hi anyone can help me? why it's not running?
#include <stdio.h>
#include <tbb/tbb.h>
using namespace tbb;
class FibTask: public task {
    public:
    const long n;
    long* const sum;
    FibTask(long n_,long* sum_ ) : n(n_), sum(sum_)
     task* execute() {
            long x, y;
            FibTask& a = *new( allocate_child() )
            FibTask(n-1,&x);
            FibTask& b = *new( allocate_child() )
            FibTask(n-2,&y);
            set_ref_count(3);
            spawn( b );
            spawn_and_wait_for_all( a );
            *sum = x+y;
        return NULL;
long ParallelFib(long n ) {
    long sum;
    FibTask& a = *new(task::allocate_root())
    FibTask(n,&sum);
    task::spawn_root_and_wait(a);
    return sum;
// Fibonacci paralelo.
int    main() {
    long int n = 30;
    task_scheduler_init init(task_scheduler_init::automatic);
    init.initialize();
    printf("%ld",ParallelFib(n));
    init.terminate();
    return 0;
Gregory_G_
ooops,
#include <stdio.h>
    public:
    const long n;
    long* const sum;
     task* execute() {
            long x, y;
            FibTask(n-1,&x);
            FibTask(n-2,&y);
            set_ref_count(3);
            spawn( b );
            *sum = x+y;
        return NULL;
    long sum;
    FibTask(n,&sum);
    return sum;
int    main() {
    long int n = 30;
    init.initialize();
    ParallelFib(n);
    init.terminate();
    return 0;
Gregory_G_
Segmentation falt
RafSchietekat
Black Belt
You don't terminate the calculation. The User Guide does so by delegating the calculation to SerialFib below Cutoff, and SerialFib returns n below 2: 0, 1, … You can eliminate SerialFib, but not the special treatment below n=2.
Gregory_G_
Thank's Raf,
Now it works!
the final version is
#include <stdio.h>
long SerialFib(long n ) {
    if( n<2 )
        return n;
    else
    return SerialFib(n-1)+SerialFib(n-2);
    public:
    const long n;
    long* const sum;
     task* execute() {
        if ( n < 2) {
            *sum = SerialFib(n);
        } else {
            long x, y;
            FibTask& a = *new( allocate_child() ) FibTask(n-1,&x);
            FibTask& b = *new( allocate_child() ) FibTask(n-2,&y);
            set_ref_count(3);
            spawn( b );
            *sum = x+y;
        return NULL;
    long sum;
    FibTask& a = *new(task::allocate_root()) FibTask(n,&sum);
    return sum;
int    main() {
    init.initialize();
    printf("%ld",ParallelFib(40));
    init.terminate();
    return 0;
It's right isn't it?
RafSchietekat
Black Belt
Except that you shouldn't switch to SerialFib only for n smaller than 2 (now you might as well return n instead and get rid of SerialFib). The role of SerialFib in the User Guide example is to give at least tasks at the lower levels enough work that average parallel overhead, even with tasks already orders of magnitude cheaper than threads, remains limited. Here it dominates because no task has more than a few instructions of useful work. See "User Guide>Parallelizing Simple Loops>parallel_for>Controlling Chunking" for a nice explanation of the principle.
