How Is Continuation Implemented
christiecohen
I saw it use a allocate_continuation_proxy.
But I don't find how it works.
As you described, the continuation merchanism reduced the stack overflow issue.
I suppose it changes the recursive call to some other logic
How does it works?
RafSchietekat
Valued Contributor III
If you have studied tutorial and reference manual for all you need to know from a user's point of view and are stillcurious aboutsome of the implementation details, you may find thread "Understanding Internals of tbb::task" interesting.
