How do you build TBB using MinGW-w64 ?
John_S_20
I'm trying to build TBB using MinGW-w64, but when I execute the build command:
    mingw32-make compiler=gcc arch=intel64
I get the following error:
    *** No rule to make target `concurrent_hash_map.o', needed by `tbb_debug.dll'.  Stop.
The complete console output is as follows:
    Created .\\build\\windows_intel64_gcc_mingw4.7.1_release and ..._debug directories
    c:/mingw64/bin/mingw32-make -C ".\\build\\windows_intel64_gcc_mingw4.7.1_debug"
     -r -f ../../build/Makefile.tbb cfg=debug tbb_root=../..
    mingw32-make[1]: Entering directory `c:/tbb41_20120718oss/build/windows_intel64_gcc_mingw4.7.1_debug'
    ../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=intel64 compiler=gcc os=windows runtime=mingw4.7.1
    mingw32-make[1]: *** No rule to make target `concurrent_hash_map.o', needed by `tbb_debug.dll'.  Stop.
    mingw32-make[1]: Leaving directory `c:/tbb41_20120718oss/build/windows_intel64_gcc_mingw4.7.1_debug'
    mingw32-make: *** [tbb] Error 2
EDIT:
I was able to compile after I downloaded the latest mingw32-make.exe from http://sourceforge.net/projects/mingw-w64/files/External%20binary%20packages%20%28Win64%20hosted%29/make/ and replaced the old one with it.
Vladimir_P_1234567890
hello John, We have not tried mingw 4.7 yet so thank you for providing a solution for possible problems there. --Vladimir
