I've defined this reduction in OpenMP:
std::vector<FindAffineShapeArgs> v; #pragma omp declare reduction(mergeFindAffineShapeArgs : std::vector<FindAffineShapeArgs> : omp_out.insert(omp_out.end(), omp_in.begin(), omp_in.end())) #pragma omp parallel for collapse(2) schedule(dynamic,1) reduction(mergeFindAffineShapeArgs : findAffineShapeArgs) for(int i=0; i<n; i++){ v.push_back(//something); }
In few words, the reduction operation appends each local version of `v` to the global one.
I've never used TBB before, but I've read this, this and this tutorial, but I don't even understand if this is even possible in TBB.
Can someone help me with this please?
Hi Luca,
Let me show the idea with lambda-based interface. The idea is similar to the OpenMP version: we need to specify the reduction loop with the first lambda and the reduction operation with the second lambda. With std::vector<int>() we specify the identity value (the value used to initialize each partial result).
std::vector<int> v = tbb::parallel_reduce(tbb::blocked_range<int>(0, n), std::vector<int>(), [](const tbb::blocked_range<int>& r, std::vector<int> v) -> std::vector<int> { for (int i = r.begin(); i != r.end(); ++i) v.push_back(i); return v; }, [](std::vector<int> v1, std::vector<int> v2) -> std::vector<int> { v1.insert(v1.end(), v2.cbegin(), v2.cend()); return v1; } );
Alex
