Hello everyone!
I have a problem relating to TBB. I recently downloaded it (the Commercial-Aligned Open Source version) onto a Windows XP PC with Microsoft Visual Studio 2008 Express and Microsoft Visual Studio 2010 Express (All four products, Visual Basic, Visual C++, Visual C#, and Visual Web Developer for both installations). I found a tutorial (http://llpanorama.wordpress.com/tbb-tutorial/) but I dont have the required software (Microsoft Visual Studio 2005 Express, which is not supported anymore, or end-of-life, and which also cant be downloaded anymore). How can I install TBB with Visual Studio 2010 Express (or if I have to, Visual Studio 2008 Express)?
Thanks in advance!
Edit: I needed Microsoft Visual Studio 2005 Express for Microsoft Assembler
BTW, here are the specs of the system I am using for TBB (in case you need it):
CPU: AMD Phenom 9650 Quad-Core Processor (2.3 GHz) (TBB said in the release notes: "Non Intel processors compatible with the above processors"; with "above processors" it meant Intel processors)
RAM: 2 GB
Video Card: NVIDIA GeForce 9600 GSO
Thanks! I'll tell you if it works! :-)
It doesn't work. :-( I moved the contents of the unzipped dir to C:\Program Files\Intel\TBB\3.0 Update 1 Commercial-Aligned Release\ and went to its bin folder with vs command prompt 2010. Next, I typed tbbvars. A list of arguments came up, so I reran tbbvars with the arguments I needed, ia32 and vs2010. I got the following error:
The system cannot find the batch label specified - ParseArgs
I looked into the batch file and there it was, ParseArgs:
:ParseArgs
:: Parse the incoming arguments
if /i "%1"=="" goto SetEnv
if /i "%1"=="ia32" (set TBB_TARGET_ARCH=ia32) & shift & goto ParseArgs
if /i "%1"=="intel64" (set TBB_TARGET_ARCH=intel64) & shift & goto ParseArgs
if /i "%1"=="vs2005" (set TBB_TARGET_VS=vc8) & shift & goto ParseArgs
if /i "%1"=="vs2008" (set TBB_TARGET_VS=vc9) & shift & goto ParseArgs
if /i "%1"=="vs2010" (set TBB_TARGET_VS=vc10) & shift & goto ParseArgs
if /i "%1"=="all" (set TBB_TARGET_VS=vc_mt) & shift & goto ParseArgs
For some reason, the batch file can't find it! :-( Do you know what's going on?
if ("%VS100COMNTOOLS%") NEQ ("") set vc_dir=vc10
I believe this change and setting the environment variable TBB30_INSTALL_DIR was all that was required to build from from the *_cl.sln files (there will be a conversion required).
For meaningful output, I sometimes had to run from the command line (use the Visual Studio 2010 command prompt).
I also saw what I interpreted as timing issues when building a solution containing several projects (e.g., sub_string_finder). One or more projects will have an error resembling this:
2>FileTracker : error FTK1011: could not create the new file tracking log file: C:\Users\mcb\AppData\Local\Temp\tbb_examples\sub_string_finder_cl\x64\Release\link.read.1.tlog. The file exists.
However the easy work around is to build by project.
HTH.
-Michael
Somehow this file contains linux end-of-lines. Could you run unix2dos utility on that file?
I'll try to find out why it contains linux eol.
thanks
--Vladimir
Just so you know, I don't really use Linux. (I dual-boot Kubuntu and Windows XP, but Kubuntu got corrupted when I tried to upgrade. Some day I'll have to fix it.) My problem's on Windows XP. "Tux, the Linux Penguin" is just my display name. :-) Thanks for replying though.
I ran unix2dos in cygwin on tbbvars.bat, and then ran tbbvars. There were no error messages. However, I don't think the paths got updated. (There was nothing related to tbb in the path) Did unix2dos affect the functionality of tbbvars.bat? Sorry this is taking so long!
I just calculated the md5 hashes. The first one is after unix2dos. The second one is before.
4f0009046530620836d93d6f5e7fe9e0 tbbvars.bat
5529187f5eb823d13be2d1bc3be68c2f tbbvars.bat
EDIT: I compared them with notepad++, but found no differences. Maybe notepad++ shows linux eols and dos linebreaks as the same... :-/
Thanks for responding! The line you told me to add was already there. I set the TBB30_INSTALL_DIR and ran copy_libraries.bat, but there was an error: Error occured in libraries copying during post-build step. copy_libraries.bat probably needs some arguments. Can you give more clear instructions? Thanks!
ia32 debug "$(OutDir)"
To be honest, I may have sent you in the wrong direction. I'm using Visual Studio 2010 Professional - I didn't realize the limitations of Visual Studio 2010 Express until I read your linked tutorial. FYI, you can download and use Professional free for 3 months.
-Michael
Sorry I didn't check twice before posting.
-Michael
Hi Michael!
Thanks for the info! Now I know what copy_libraries.bat is. :-) Thanks again!
Thanks for the tip! :-) I think I should try manually changing the paths on vs2010. Do you think I should? I'll tell you if it works.
Update:I didn't manually change the paths, but just then I found something called generate_tbbvars.bat. I ran it, and it generated a tbbvars.bat file. Here are the contents:
[bash]@echo off SET TBB30_INSTALL_DIR= SET TBB_ARCH_PLATFORM= SET TBB_TARGET_ARCH= SET INCLUDE=%TBB30_INSTALL_DIR%include;%INCLUDE% SET LIB=C:Program FilesIntelTBB3.0 Update 1 Commercial-Aligned Releasebin;%LIB% SET PATH=C:Program FilesIntelTBB3.0 Update 1 Commercial-Aligned Releasebin;%PATH% [/bash]I ran it, and the paths were updated! However, when I ran the fibonacci example, the tbb include files were not detected. I had to insert the full path forthe includes to work. Even then, a library, tbb_debug.lib, was not found. Strange.
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
