2485 Discussions
How to refactor ipp_resize_mt example to a flow graph?
renegr
I'm new to flow graphs. I like the idea behind it but I already broke up in refactoring a resize filter to be a node of a flow graph. Could you please give me some hints?
Next I also want to use the flow graph to build a histogram on each tile and at after the last tile was processed calculate the final histogram. So how do I detect the last tile?
Thanks in advance
renegr
While thinking more and more about it, it seems that a pipeline does reflect the processing better. Anyway the problem stays the same.
