How to solve AX=B using c++with tbb.
gaocheng073
Hi ,
Who has the code or the experience to solve(mutrix function) AX=B using c++with tbb.
Could you share them with me . Thanks in advance.
SergeyKostrov
Valued Contributor II
Quoting gaocheng073
...Who has the code or the experience to solve(mutrix function) AX=B using c++with tbb...
Please take a look at a 'Parallel_do' example in '..\Examples' folder.
Sergey
gaocheng073
Hi ,
I am sorryI cannot find my 'Parallel_do' example in '..\Examples' folder.
Can you help me and tell me why .
If you have it,please send it to me .
Thank you very much.
SergeyKostrov
Quoting gaocheng073
Hi ,
I have two TBB versions on my computer:
version 4.0initial release
version 4.0 update 3 ( Commercially Aligned Release )
and both have the 'Parallel_do' example in '..\Examples' folder.
Please verify whatversion you have on your computer.
RafSchietekat
Valued Contributor III
The example itself is "parallel_preorder", grouped with 0 other examples in a directory examples/parallel_do, but I don't see any parallelised matrix computatiion code in it, so...
