2455 Discussions
How to solve Segmentation fault when running TBB on Linux? How to free this memory?
Jakcie_Jin
I originally built my TBB code on Windows and it worked fine. Today I moved my code to Linux system (OpenSUSE).
When I tried to run it, I got Segmentation fault. The TBB version I used is TBB21. I also checked where the probelm occured.
and I found it happened when it got to task::spawn_root_and_wait(tl) becuase I could get the cout information before that line and could not get the cout information after that line; The part of code is put below.
SolverP2 Improve(&inst,&mysolution,StartSolT1,&P1Queue,&P2Queue,&P3Queue,iterControl,exchangeControl,&stopControl );
task_list tl;
P2MainTask& a=*new(task::allocate_root()) P2MainTask(&Improve);
tl.push_back(a);
SolverP2T2 Thread2(&inst,&mysolution,StartSolT2,&P1Queue,&P2Queue,iterControl,exchangeControl,&stopControl );
P2Thread2Task& b=*new(task::allocate_root()) P2Thread2Task(&Thread2);
tl.push_back(b);
SolverP2T3 Thread3(&inst,&mysolution,StartSolT3,&P1Queue,&P3Queue,iterControl,exchangeControl,&stopControl );
P2Thread3Task& c=*new(task::allocate_root()) P2Thread3Task(&Thread3);
tl.push_back(c);
Shaking shakeSol(&inst,&mysolution,StartSolT4,&P4Queue,&stopControl );
ShakingTask& d=*new(task::allocate_root()) ShakingTask(&shakeSol);
tl.push_back(d);
cout<<"task deine finished"< task::spawn_root_and_wait(tl);
cout<<"task start finished"<
Could you tell me how to solve this problem? Thanks. In addition I ran a exampel TBB code on this Linux system. It worked.
In addition, after finish these tasks, how can we release the memory defined by new for resue? Thanks!
Krishna_R_Intel
Thanks for using the forum. Is it possible for you to share your sample code where you observed the problem? I'll try to run it here and report what I find and we can go from there. If in case you want to share code, please e-mail it to NOSPAMkrishna.ramkumar@intel.com (remove NOSPAM).
Krishna
