Now I have a solver in that I need to keep a set of self-defined data type objects in a concurrent_vector or queue. It has to be concurrent because the objects come from different threads.With this concurrent container, I hope to sort these objects, eliminate duplicates and send them back when other threads need them.
However, I know TBB offers concurrent_vector and concurrent_queue which can be read and written concurrently from different threads. But how to sort the objects inside a container? Does everyone know how to do that? Thanks.
How about using the heap operations of C++, with appropriate use of locks of course?
In addition, what is the heap operations of C++?
Is it that recursive split ordering with the second name "trash your cache" (consecutive nodes scattered as far as possible from each other)?.. Oh, never mind.
I can't understand if I can use tbb:parallel_sort with tbb concurrent vector?
tbb::concurrent_vector<int> tbb_vec; // ...fill tbb_vec // sort tbb::parallel_sort(tbb_vec.begin(), tbb_vec.end());
Hi Alex,
I suppose it should work. Have you tried it? Have you faced some issues?
Regards, Alex
