How to use Concurrent Hashmap in my code
Arvind_D_
Hi
I have a concurrent hashmap defined like this- This is straight from an example in TBB code.
typedef concurrent_hash_map<MyString,int> StringTable;
Now, how do I do the following with it-
(1) Add data to it
(2) Delete data from it
(3) Find a data in it
(4) Update a key pair value
(5) Modify a key pair value ie data
The example uses the hashmap in a for loop where the above are not implemented.
Yours sincerely,
Arvind.
