The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
2442 Discussions
How to use parallel_for on my own defining struct .
gaocheng073
Hi ,professors,
When i use parallel_for on my defining struct ,It can not work.
The part of my code is :
struct Result //This is my defining struct.
int Path;
double Amp;
double Phase;
void apfft(Result* T); //This is my defining function.
Result FFTResult; // This is my defining array.
for(int i=0;i{
FFTResult.Path=i;
FFTResult.Amp=0;
FFTResult.Phase=0;
apfft(&FFTResult);
The following is my parallel code , but it does not work.
class ParaFFT
void operator()(const blocked_range&range)const
for(int i=range.begin();i!=range.end();++i)
FFTResult.Path=i;
FFTResult.Amp=0;
FFTResult.Phase=0;
apfft(&FFTResult);
parallel_for(blocked_range(0,L-1,1),FFTResult);
I try it many days,but i found i can not translate my own defining struct .
Please help me or instruct me . Many thanks.
RafSchietekat
Black Belt
"parallel_for(blocked_range(0,L-1,1),FFTResult);"
The second parameter in a blocked_range constructor is exclusive (please check if this is what you meant), the second parameter in parallel_for should be a Body (FFTResult won't do what you want).
gaocheng073
My problem has beensolved.Thank you very much!
