How to use parallel_reduce for vector
FlorentD
I need to analyze N nodes that will generate M new nodes using parallel_reduce :
struct MyReduction {
    MyClassPtr* _this = nullptr;
    const std::vector<Node*>& bestNodes;
    std::atomic<size_t> threadId{0};
    std::vector<Node*> value;
    MyReduction(MyClassPtr* _t, const std::vector<Node*>& n) : _this(_t), bestNodes(n) {}
    MyReduction(MyReduction& s, tbb::split) : _this(s._this), bestNodes(s.bestNodes) {
        threadId = 0;
        value = std::vector<Node*>();
    void operator()( const tbb::blocked_range<size_t>& r ) {
        const auto lThreadId = threadId++; // atomic
        auto tmp = value;
        const auto tab = _this->_analyseNodes(bestNodes, r.begin(), r.end(), lThreadId);
        tmp.insert(tmp.end(), tab.cbegin(), tab.cend());
        value = tmp;
    void join(MyReduction& rhs) {
        value.insert(value.end(), rhs.value.begin(), rhs.value.end());
And the call :
MyReduction result(this, bestNodes);
tbb::parallel_reduce(tbb::blocked_range<size_t>(0, bestNodes.size()), result);
The result after the reduction, i.e variable "result.value" is not correct and I think there is a data race inside the operator() because I never have the same size of this vector.
If I add a mutex inside the operator() function, it works...
        static std::mutex mutex;
        mutex.lock();
        auto tmp = value;
        value = tmp;
        mutex.unlock();
What is wrong with my reduction ?
Note that if I use the lambda version of parallel_reduce, it works perfectly but I want to use the imperative form to avoid temporaries and copies.
NoorjahanSk_Intel
In order to remove data races in the code, one way of synchronization methods is musing mutexes as these are used to simplify writing race-free code.
Please refer to the below link for more details:
https://oneapi-src.github.io/oneTBB/main/tbb_userguide/Mutual_Exclusion.html
>>What is wrong with my reduction?
Could you please help us in reproducing your issue by providing the complete reproducer and expected results?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Noorjahan.
NoorjahanSk_Intel
We have not heard back from you, so we will close this inquiry now. If you need further assistance, please post a new question.
Thanks & Regards,
Noorjahan.
