I am needing some per thread scratchmemory where I can store some temporary values. This scratchmemory needs to be fairly large (several MB or so), so I dont want to allocate that on the stack.
I guess this is what thread local storage is for but I have some trouble understanding how I can use the TBB combinable classes for it and which exactly I would need.
Are there any examples on how to use it? Assuming I have a main thread that executes several tasks, how and when do I allocate the memory? How do I access the memory? Do I need memory per Task-Type or can I have something like a global scratchmemory my different tasks can access to store temporary values?
Any help would be welcome
Michael
Michael
Michael,
This is one way to do it.
struct YourStruct_t
... // things you want thread private
__declspec( thread )
YourStruct_t* pYourStruct = NULL;
// called by each thread sometime before first use
void YourThreadInit()
if(!pYourStruct) pYourStruct = new YourStruct_tl
Note, you can have individual items with __declspec( thread ). I prefer to use an encapsulation within a stucture.
** generally you want to deferr the ctor until running in thread context **
Jim Dempsey
struct YourStruct_t
Jim Dempsey
I need to do this with the TBB so I have essentially no info about threads, just tasks. Or can I just call
inside a task?
Michael
inside a task?
Michael
Yes, you simply call that within your task.
YourStruct_t pYourStruct = NULL;
Creates a thread private pointer named pYourStruct and initialized to NULL.
Then whenever your code dereferences the pYourStruct, it generates some additional code to obtain it from a thread private area. You can see this code in a dissassembly window.
Each thread will have a private copy of the pointer (and everything else you decorate with __declspec( thread )).
Each thread that uses this poiner must initialize the pointer and any corrisponding allocations within the struct.
You can use this technique with OpenMP theads, PThreads, Cilk++ threads, etc...
g++ uses a different syntax to mark threads private
#if defined(__GNUC__)
#define __TLS__ __thread
#else
#define __TLS__ __declspec( thread )
#endif
__TLS__ YourStruct_t* pYourStruct = NULL;
Jim Dempsey
#else
#endif
Jim Dempsey
TBB Reference contains an example how to use enumerable_thread_specific template class. combinable template class can be used in a similar manner.
MSDN contains a page with an example of using Concurrency::combinable: http://msdn.microsoft.com/en-us/library/dd728079.aspx. Since TBB implementation is compatible, it should work with TBB as well.
Thanks to you both, I will try that.
