I'm using atomic operations to implement mutex and cond (i'm currenting using threadpool using posix threads and now need to move to tbb).
For example i'm doing something like this:
Lock_mutex (mutex * m){
while (T&S(TS_Object *) m);
Unlock_mutex(mutex *m){
Reset((TS_Object *) m)
(this is just pseudo code, the param is actually an atomic operation).My problem is with implementing pthread_cond_wait and pthread_cond_signal
using only T&S or C&S.
Can anyone directs me please?
Thanks in advanced,
Shay.
This is actually the functions for T&S:
T&S (T&S_object * TS)
If (TS.flag==false) {
TS.flag = true;
return false;
} else return true;
Reset (T&S_object * TS)
TS.flag=false;
Real-world condition variables usually block threads. Blocking can't be implemented with atomic operations.
If you need only a toy implementation, then you can implement wait() as unlock-yield-lock, and signal() as no op. No need for atomic operations either.
Thanks for the really fast reply,
i'm not familiar with unlock-yield-lock, can you link me to a code example maybe?
and also, how can i signal other threads in my threadpool that a job is done if i made this function no op?
void condvar_wait(mutex* m)
Unlock_mutex(m);
pthread_yield()/SwitchToThread();
Lock_mutex(m);
void condvar_signal/broadcast()
Since threads are not blocked, there is no need to signal them - they are always ready notice any state change.
Excellent, thanks a lot.
Is there anequivalent for pthread_yield in tbb's library?
or i should implement one myself?
Quoting shay86
tbb::this_tbb_thread::yield() in
Has anyone tried emulating condition variables with dummy child tasks and continuations?
don't you want to use tbb's condition variable?
--Vladimir
