Implicit vs Explicit Task Creation
nagy
What are the performance differences between implicit task creation e.g
[cpp]tbb::parallel_invoke
         tbb::parallel_for( /* .... */ );
       // Work
    // Work
});[/cpp]
vs explicitly allocating tasks, spawning them, and maybe recycling them.
Dmitry_Vyukov
Valued Contributor I
In general, implicit task creation (especially algorithms like parallel_for) should be considered as more efficient, because that way your program communicates much more information to a tasking library. A library receives information about algorithm structure, total task count, task sizes (algorithms like parallel_for assume roughly equal size tasks), etc. While with explicit task creation a tasking library operates mostly "blindly".
RafSchietekat
Valued Contributor III
Really? I would say that the algorithms have been designed to use tasks well, by the same team and with incremental improvements based on experience, so they would be difficult to match or improve upon economically, but I'm not sure that there's much going on in the other direction. Do you have any examples?
Dmitry_Vyukov
What do you mean by "other direction"? And examples of what do you want?
RafSchietekat
Algorithms try to use tasks efficiently (they're built on top of facilities provided by the scheduler), but do you have examples of what tasks know about algorithms (the "other direction")?
Dmitry_Vyukov
No, I don't have. And I doubt they exist.
RafSchietekat
Then I guess I don't understand what you mean by "While with explicit task creation a tasking library operates mostly "blindly"".
Dmitry_Vyukov
I meant that tasking library executes explicit tasks without any high-level optimizations, because it does not have any information on algorithm structure, total number of tasks, task sizes, etc.
RafSchietekat
What "high-level optimisations" that you couldn't apply yourself if you really wanted to reinvent the wheel or if you had a need not currently provided for by the provided algorithms? Do they use significant private API, perhaps? I would have to look through the sources to find out for myself, but, whileit seems interesting,it would be far easier for you to prove a positive than for me to prove a negative. :-)
