2481 Discussions
In MFC applications, how to use tbb::flow::graph?
sui1
In MFC application, I have the following code in View.cpp:
#include <tbb/tbb.h>
tbb::flow::graph g;
Then, I run this application. The error is occured as shown in the following  figure.
How can I solve this problem?
Mark_L_Intel
Hello @sui1,
    The error "?itt_region_end_v9@internal" you’re encountering is related to Intel’s Instrumentation and Tracing Technology (ITT) API, which is used for performance analysis and profiling.  Are you using ITT in your code? Could you provide a complete reproducer?
