Hi all,
I mainly work using Code::Blocks so I tried to build TBB using gcc-mingw instead of Visual Studio.
I dowloaded the src pack, however during the make I'm getting the some errors in thread_monitor.h. (I've copy pasted bellow).
Just in case I installed the pthread library for win32, but still have the same errors.
Does anyone have an idea about the issue and how to fix it?
Thanks in advance!
C:\Program Files\Intel\TBB\2.2>make arch=ia64 compiler=gcc
cd ".\\build\\windows_ia64_gcc_mingw_release" && cmd /C "..\..\build\generate_tbbvars.bat" windows_ia64_gcc_mingw_release
Generating tbbvars.bat
Generating tbbvars.sh
Generating tbbvars.csh
cd ".\\build\\windows_ia64_gcc_mingw_debug" && cmd /C "..\..\build\generate_tbbvars.bat" windows_ia64_gcc_mingw_debug
make -C ".\\build\\windows_ia64_gcc_mingw_debug" -r -f ../../build/Makefile.tbb cfg=debug tbb_root=../..
make[1]: entrant dans le rpertoire C:/Program Files/Intel/TBB/2.2/build/windows_ia64_gcc_mingw_debug
../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=ia64 compiler=gcc os=windows runtime=mingw
g++ -c -MMD -g -O0 -DTBB_USE_DEBUG -DUSE_WINTHREAD -D__MSVCRT_VERSION__=0x0700 -msse -mthreads -D__TBB_BUILD=1 -Wall -Wno-uninitialized -Wno-parentheses
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_hash_map.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_queue.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_vector.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/dynamic_link.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/itt_notify.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/cache_aligned_allocator.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/pipeline.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/queuing_mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/queuing_rw_mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/spin_rw_mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/spin_mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/task.cpp
cmd /C cscript /nologo /E:jscript ../../build/version_info_windows.js gcc ia64 "g++ -g -O0 -DTBB_USE_DEBUG -DUSE_WINTHREAD -D__MSVCRT_VERSION__=0x0700 -ms
se -mthreads -D__TBB_BUILD=1 -Wall -Wno-uninitialized -Wno-parentheses -I../../src -I../../src/rml/include -I../../include" > version_string.tmp
-I. -I../../src -I../../src/rml/include -I../../include ../../src/tbb/tbb_misc.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/recursive_mutex.cpp
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/tbb_thread.cpp
gcc -c -MMD -g -O0 -DTBB_USE_DEBUG -DUSE_WINTHREAD -D__MSVCRT_VERSION__=0x0700 -msse -mthreads -D__TBB_BUILD=1 -Wall -Wno-uninitialized -Wno-parentheses
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/itt_notify_proxy.c
-I../../src -I../../src/rml/include -I../../include ../../src/tbb/private_server.cpp
In file included from ../../src/tbb/private_server.cpp:30:
../../src/rml/include/../server/thread_monitor.h: In static member function `static void rml::internal::thread_monitor::launch(unsigned int (*)(void*), voi
d*, size_t)':
../../src/rml/include/../server/thread_monitor.h:129: error: `uintptr_t' was not declared in this scope
../../src/rml/include/../server/thread_monitor.h:129: error: expected `;' before "status"
../../src/rml/include/../server/thread_monitor.h:130: error: `status' was not declared in this scope
../../src/rml/include/../server/thread_monitor.h:128: warning: unused variable 'thread_id'
../../src/rml/include/../server/thread_monitor.h:129: warning: unused variable 'uintptr_t'
../../src/tbb/private_server.cpp: In static member function `static unsigned int tbb::internal::rml::private_worker::thread_routine(void*)':
../../src/tbb/private_server.cpp:201: warning: converting to non-pointer type `unsigned int' from NULL
make[1]: *** [private_server.o] Erreur 1
make[1]: quittant le rpertoire C:/Program Files/Intel/TBB/2.2/build/windows_ia64_gcc_mingw_debug
make: *** [tbb] Erreur 2
d*, size_t)':
Difficult to say without knowing any version details...
Quoting - Raf Schietekat
However, I'm not getting any library file, just the dlls. SoI create them using dlltool.
To test I picked up the "sub_string_finder".
I linked the libraries to my project and tried to run, but I got the errors listing bellow.
Obviously there's something wrong with the libraries, maybeoriginallyfrom the dlls, but what?
F:tbbtestmain.cpp|48|undefined reference to `tbb::task_group_context::~task_group_context()'|
objDebugmain.o||In function `_ZN3tbb10empty_task7executeEv':|
)]+0x14)||undefined reference to `tbb::internal::allocate_root_with_context_proxy::free(tbb::task&) const'|
)]+0x14)||undefined reference to `tbb::internal::allocate_root_with_context_proxy::allocate(unsigned int) const'|
unsigned int)]+0x2f)||undefined reference to `tbb::task_group_context::init()'|
C:Program FilesCodeBlocksMinGWbin..libgccmingw323.4.5........includetbbblocked_range.h:
(.text$_ZN3tbb4taskD2Ev[tbb::task::~task()]+0xb)||undefined reference to `vtable for tbb::task'|
)]+0x16)||undefined reference to `tbb::internal::get_initial_auto_partitioner_divisor()'|
(.text$_ZN3tbb4taskC2Ev[tbb::task::task()]+0x16)||undefined reference to `vtable for tbb::task'|
)]+0x14)||undefined reference to `tbb::internal::allocate_child_proxy::free(tbb::task&) const'|
)]+0x14)||undefined reference to `tbb::internal::allocate_child_proxy::allocate(unsigned int) const'|
)]+0x14)||undefined reference to `tbb::internal::allocate_continuation_proxy::allocate(unsigned int) const'|
(.rdata$_ZTVN3tbb10empty_taskE[vtable for tbb::empty_task]+0x14)||undefined reference to `tbb::task::note_affinity(unsigned short)'|
||=== Build finished: 12 errors, 0 warnings ===|
Quoting - inddzen
Well, I just managed to resolve the problem by building from the stable release sourcetbb22_20090809oss_src.tgz instead of theCommercial Aligned Release "tbb22_009oss_src.tgz"
(Edited) If somebody has seen what I wrote here initially, I guessed there is an issue in our recent com-aligned package. A quick check, however, showed that it is not necessarily true, as I just successfully built TBB with minGW on my laptop. So it might be the problem of a particular version (or my luck to use a version without the problem). Here is what I have:
C:>gcc --version
gcc (4.3.3-tdm-1 mingw32) 4.3.3
My another concern is the specification of arch=ia64 in the command line to build TBB. What do you expect from it? And what is your environment in general?
As for the library files being absent: I believe
The gcc compiler that comes with Code::Blocks is rather old. And the VisualC++ compiler (not the visual studio)is completely free and quite good. You can still use Code::Blocks with it.
