Hello~
I am trying to integrate the perfmon library to TBB to give the task scheduler some extra hardware information.
However, I need to modify the Makefile to link an extra libpfm.a file provided by perfmon library.
I have scaned through the Makefiles in TBB package but still don't know how to do this.
Could you please help me with this problem
Any help would be grateful!!
Dennis
hi Dennis,
LIBS variable is responsible for this. It is set in compiler-specific include files i.e. linux.icc.inc for the Intel compiler or linux.gcc.inc for the gcc.
Vladimir
Quoting - irisshinra308
Hello~
Dennis
may I also ask you what kind of additional hardware information you want task scheduler to have and what is the purpose of it?
Thanks for the reply. That do help me a lot!!
After solving the library problem, I want to add a new cpp file into the src/tbb directory.
How should I modify the Makefile to compile the my new cpp file and link the corresponding object file?
I have try to compile the new cpp file into a object file manually and put the object file into the build diretory.
Then I add the object file into the TBB_CPLUS_OBJ in the Makefile.tbb.
However, the error message shows that the newly added object file could not be found.
Dennis
Quoting - Anton Pegushin (Intel)
Hello Dennis,
I am trying to make the task scheduler aware of the cache interference between threads.
Then I would try to solve this interference problem by re-scheduling tasks to lower the required cache footprint.
Dennis
I assume you mean "TBB_CPLUS.OBJ" instead of "TBB_CPLUS_OBJ"? Did you use a backslash at the very end of the line? What is the error message?
