2455 Discussions
Intel® Composer XE 2013 Update 4 and standalone Intel® TBB 4.1 update 3
Vladimir_P_1234567890
Hello all
Intel® Software Manager and Standalone Intel® TBB 4.1 update 3 (or IPP  update 3) does not recognize a confict with the latest composer xe update that was released a few days ago that leads to Visual Studio 2010 failure after standalone install.
The fix will be availalbe in the next update. Working scenario is to not install standalone update 3 since TBB update 3 is a part of the composer update 4.
But in case you installed update 3 our install team confirmed that the right solution to fix the problem is provided by customers and it is:
    1. Uninstall the Intel TBB
    2. Run the Intel Composer C++ Update 4 for Windows Installer and choose modify, unistall visual studio integration.
        At this point, you can open VS and see if the problem is fixed.
    3. Re-run the Intel Composer C++ Update 4 for Windows Installer, choose modify and install visual studio integration and TBB.
    4. Do not re-run the standalone Intel TBB  update 3 install.
More details are there http://software.intel.com/en-us/forums/topic/393186
--Vladimir
The problem should be fixed in recently  released Intel® TBB 4.1 update 4.
--Vladimir
Rodney_H_
I installed TBB4.1 Update 4 and it wrecked my VS2012 installation, in the same way Update 3 did and was reported here:http://software.intel.com/en-us/forums/topic/393186
hello. have you installed this update on top of composer xe update 4 or composer xe update 5?
