Intel(R) TBB 4.2 update 3 is released and available for download
Vladimir_P_1234567890
Changes (w.r.t. Intel TBB 4.2 Update 2):
  • Added support for Microsoft* Visual Studio* 2013.
  • Improved Microsoft* PPL-compatible form of parallel_for for better support of auto-vectorization.
  • Added a new example for cancellation and reset in the flow graph: Kohonen self-organizing map (examples/graph/som).
  • Various improvements in source code, tests, and makefiles.
Bugs fixed:
  • Added dynamic replacement of _aligned_msize() previously missed.
  • Fixed task_group::run_and_wait() to throw invalid_multiple_scheduling exception if the specified task handle is already scheduled.
Open-source contributions integrated:
  • A fix for ARM* processors by Steve Capper.
  • Improvements in std::swap calls by Robert Maynard.
You can download Intel TBB 4.2 update 3 from commercial and open source sites.
RafSchietekat
Valued Contributor III
I disagree with the fix for ARM: this should be just the ISB instruction, not a full fence. The thing with swap seems the rather unfortunate forced outcome of a strange and in my opinion indefensible quirk about C++ namespaces.
episteme
I can't find "vs12_ui" at bin,lib dir.
this update does NOT support StoreApp? or combined with "vs12"?
hi episteme,
binaries for storeapp applications are located in vc11_ui. If you use visual studio 2013 you can use debug libraries from vc12 folder for debug config and release vc11_ui for release config. Do you need storeapp-specific libraries for visual studio 2013?
--Vladimir
episteme
this means to build StoreApp for Win8.1 by vc12, use TBB-libs in vc_11?
"vc11_ui" libraries. It is next to vc11 folder
--Vladimir
