Intel Thread Checker 3.1 on RHEL 5.4
K__Eric_Harper
I realize that Thread Checker 3.1 has not been validated on RHEL 5.4 (install warning). When I run tcheck_cl on the primes example I get the error message: "/tcheck/primes/./primes.gcc: (E) Cannot run Instrumentor. AddTraces_TC32e -r /tmp/_tc_cl_cache/primes.log -recorder libtctrace.so -config /opt/intel/itt/tcheck/bin/32e/tcheck10.ini -itt_timestamp 1172536335 -instr_type partial:
Created INI file: /tmp/_tc_cl_cache/primes.ini"
Can you provide guidance for how to work around this issue? Thanks in advance.
K__Eric_Harper
I am happy to report that this issue has been resolved with guidance from Intel Premier Support. I was not running the latest version of Intel Thread Checker for Linux 3.1. After upgrading the problem went away.
