2457 Discussions
Is TBB available for MacOS using PowerPC processor?
Jaime_Rios
Searching around the forum I see that the open source version of TBB has been ported to Linux running PowerPC processors, but has there been any attempts at doing the same for MacOS?
Thanks!
-Jaime
Vladimir_P_1234567890
Itused to work on MacOS running on G4 and G5 CPUs, both 32 and 64 bit versions. But i'm not sure if it still works there. If the latest stable release does not work you can try tbb 2.1 or 2.2 comm-aligned releases. Please let us know the results of your try.
thanks.
--Vladimir
Jaime_Rios
I wish I could report some good news but there was a whole licensing issue I ran into when trying to solve this problem.
Sadly, I had to abandon the work on this particular task.
Thanks again for your answer.
