2472 Discussions
Is there a way to limit the number of cores used by a call to a parallel function?
Victor_D_
For example fill(dpl:) does not scale in parallel well, and I'd like to limit it to using 2 or 4 cores, while sort(dpl:) scales better and I'd like to let it use more cores within the same application.
Thank you,
-Victor
SeshaP_Intel
Could you please provide the following details you were using so that we can investigate the issue more from our end?
1. oneTBB version you are using?
2. Operating system and Hardware details
3. Complete reproducer code and steps(if you have followed any)
Thanks and Regards,
Pendyala Sesha Srinivas
SeshaP_Intel
We haven't heard back from you. Could you please provide an update on your issue?
Thanks and Regards,
SeshaP_Intel
I have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
Pavel_K_Intel1
There are several approaches in oneTBB.  However, based on your description task_arena should be appropriate solution.
You can wrap particular algorithm into task_arena::execute.
#include "tbb/task_arena.h"
int main() {
    tbb::task_arena sort_arena(concurrency);
    sort_arena.execute([] {
        // call sort function
Victor_D_
Thank you Pavel for your suggestion. I'll give task arena a try.
