hi..
i'm using Intel TBB 2.1 with OpenCV and Microsoft Visual Studio 2008 express edition.
while implementing parallel_for function, i get a run-time error that says:
An unhandled win32 exception occurred ...[5556]. Just-in-Time debugging this exception failed with the following error: No installed debugger has just-in-time debugging enabled.
express edition doesnt support JIT debugging. is it essential to have a JIT debugger to use TBB?
also, why do you think the error occurs?
this is the code snippet thats causing the problem:
class ApplyFoo {
IplImage **const my_a;
public:
void operator()( const blocked_range& r ) const {
IplImage **a = my_a;
for( size_t i=r.begin(); i!=r.end(); ++i )
DCTscramenc(a);
ApplyFoo( IplImage* a[] ) : my_a(a)
void ParallelApplyFoo( IplImage* a[], size_t n ) {
printf("parallel enter\n");
parallel_for(blocked_range(0,n), ApplyFoo(a),auto_partitioner());
the error pops-up as soon as there is a call to the ParallelApplyFoo function:
ParallelApplyFoo(image,4);
(where image is of Ip
can someone help me sort this out?
thanks and regards,
sindhura
class ApplyFoo {
public:
DCTscramenc(a);
thanks and regards,
sindhura
Quoting - sindhura.t
hi..
class ApplyFoo {
public:
DCTscramenc(a);
printf("parallel entern");
thanks and regards,
sindhura
class ApplyFoo {
public:
DCTscramenc(a);
thanks and regards,
sindhura
Hi sindhura.t,
I've always used Intel TBB with Visual Studio Team System. However, I know that Express Editionsdon't support Just-In-Time Debugging. Check this link from Microsoft: http://msdn.microsoft.com/en-us/library/5hs4b7a6.aspx
Your application is having a problem, and VS tries to launch JIT debugger.
are there any conditions in the code i gave above, with respect to tbb usage, that would result in such a error?
Some essential text seems to have disappeared near "where image is of" in the original posting.
I see nothing obvious, but, if you don't get past the printf() call ("as soon as there is a call to the ParallelApplyFoo function"), how is this related to TBB?
thanks for replying...
i wasn't initialising task scheduler correctly... my bad. i'm very new to tbb.
