LLVM / Clang
Suminda_D_
Any LLVM / Clang ports available for TBB?
Suminda
Vladimir_P_1234567890
yes, development release does have such port for os x.
--Vladimir
RafSchietekat
Valued Contributor III
CHANGES says support for OS X was added in TBB 4.0 Update 4 and further improved in TBB 4.1 Update 3 (those are stable releases).
Use on GNU/Linux has been demonstrated, but is not yet supported.
Suminda_D_
I am not looking for OS X. I am looking to use Clang on Windows. Can I use TBB.
Is the OS X port compatibe with Clang?
Where can I get the lib for this?
hello Suminda,
For windows we do not have a contribution for clang yet. but I think it should not be very difficult comparing to mingw's gcc. So if you make it please submit it via http://threadingbuildingblocks.org/submit-contribution
thanks!
--Vladimir
