2485 Discussions
License requires Intel permission to use FOSS version tbb
Laura_B_
TBB version 2.2.2 has a copyright that states Intel permission is needed for use.  Can you please confirm either we are permitted to use the tool or let me know if the copyright was unintentionally left in the Open Source version.
There is a license included in this open source version of TBB found in source code and documentation described in tbb-V2.2-2.20090809 -/
tbb22_20090809oss_src.tgz/ tbb22_20090809oss_src/ tbb22_20090809oss/ doc/ html/
Copyright 2005-2009 Intel Corporation. All Rights Reserved
The source code contained or described herein and all documents related to the source code ("Material") are owned by Intel Corporation or its suppliers or licensors. Title to the Material remains with Intel Corporation or its suppliers and licensors. The Material is protected by worldwide copyright laws and treaty provisions. No part of the Material may be used, copied, reproduced, modified, published, uploaded, posted, transmitted, distributed, or disclosed in any way without Intel's prior express written permission.
No license under any patent, copyright, trade secret or other intellectual property right is granted to or conferred upon you by disclosure or delivery of the Materials, either expressly, by implication, inducement, estoppel or otherwise. Any license under such intellectual property rights must be express and approved by Intel in writing.
Thank you.
Laura
Vladimir_P_1234567890
Hello Laura, Thank you for you report. This is a technical error. As we stated before our open source releases contain as the same binaries and sources as commercial releases except license info and this confusion was introduced by one of scripts. We have fixed the script and coming releases including just released development release will contain correct (Open Source) headers. Thanks, --Vladimir
