Link error: cannot open file 'tbb_dll.lib'
MemoryLeak
Hey Guys,
I'm using Windows 10, Version 10.0.18362 Build 18362, on a x64-based Intel Core i7 processor. I installed MKL using w_mkl_2020.4.311.exe and it perfectly integrated into my Visual Studio 2019. After that I installed TBB using w_tbb_2020.3.311.exe, which also integrated into my Visual Studio 2019. Furthermore I set the environment by ".\tbbvars.bat intel64 vs2019".  When I switch TBB on by Project Property Page > Configuration Properties >  Intel Performance Libraries > Use Intel TBB, and try to compile:
int main()
return 0;
I get:
LINK : fatal error LNK1104: cannot open file 'tbb_dll.lib'.
What am I missing???
Many thanks in advance!
Greetings, MemoryLeak
CHEN__PENGJU
Hi, I just found a solution that can solve this liking issue, but may not be correct...
you can try to rename tbb.lib to tbb_dll.lib under
C:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2020.4.311\windows\tbb\lib\intel64\vc_mt
CHEN__PENGJU
Same issue..
CHEN__PENGJU
MemoryLeak
Well,
works here, too. So far no problems, I hope it will stay like that! Thank you!
