Visual Studio 2008 Team System x64
TBB30_104oss (installed using intel64 and vs2008/vc9)
I am just starting to use TBB and just following Getting Started document. After copying tbb.dll and tbb_debug.dll from the bin (intel64 vc9 version of course) to the project folder, and modifying lib paths of the project from ia32 to intel64... i get linker errors seen below. How do I fix it?
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "void __cdecl tbb::assertion_failure(char const *,int,char const *,char const *)" (?assertion_failure@tbb@@YAXPBDH00@Z) referenced in function "public: __thiscall tbb::blocked_range
::blocked_range (unsigned int,unsigned int,unsigned int)" (??0?$blocked_range@I@tbb@@QAE@III@Z) 1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: __thiscall tbb::task_group_context::~task_group_context(void)" (??1task_group_context@tbb@@QAE@XZ) referenced in function "public: static void __cdecl tbb::internal::start_for
,class SubStringFinder,class tbb::auto_partitioner>::run(class tbb::blocked_range const &,class SubStringFinder const &,class tbb::auto_partitioner const &)" (?run@?$start_for@V?$blocked_range@I@tbb@@VSubStringFinder@@Vauto_partitioner@2@@internal@tbb@@SAXABV?$blocked_range@I@3@ABVSubStringFinder@@ABVauto_partitioner@3@@Z) 1>sub_string_finder.obj : error LNK2019: unresolved external symbol "protected: void __thiscall tbb::task_group_context::init(void)" (?init@task_group_context@tbb@@IAEXXZ) referenced in function "public: __thiscall tbb::task_group_context::task_group_context(enum tbb::task_group_context::kind_type,unsigned int)" (??0task_group_context@tbb@@QAE@W4kind_type@01@I@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: class tbb::task & __thiscall tbb::internal::allocate_root_with_context_proxy::allocate(unsigned int)const " (?allocate@allocate_root_with_context_proxy@internal@tbb@@QBEAAVtask@3@I@Z) referenced in function "void * __cdecl operator new(unsigned int,class tbb::internal::allocate_root_with_context_proxy const &)" (??2@YAPAXIABVallocate_root_with_context_proxy@internal@tbb@@@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: void __thiscall tbb::internal::allocate_root_with_context_proxy::free(class tbb::task &)const " (?free@allocate_root_with_context_proxy@internal@tbb@@QBEXAAVtask@3@@Z) referenced in function "void __cdecl operator delete(void *,class tbb::internal::allocate_root_with_context_proxy const &)" (??3@YAXPAXABVallocate_root_with_context_proxy@internal@tbb@@@Z)
1>sub_string_finder.obj : error LNK2001: unresolved external symbol "public: virtual void __thiscall tbb::task::note_affinity(unsigned short)" (?note_affinity@task@tbb@@UAEXG@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "unsigned int __cdecl tbb::internal::get_initial_auto_partitioner_divisor(void)" (?get_initial_auto_partitioner_divisor@internal@tbb@@YAIXZ) referenced in function "public: __thiscall tbb::auto_partitioner::partition_type::partition_type(class tbb::auto_partitioner const &)" (??0partition_type@auto_partitioner@tbb@@QAE@ABV12@@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "private: void __thiscall tbb::task::internal_set_ref_count(int)" (?internal_set_ref_count@task@tbb@@AAEXH@Z) referenced in function "public: void __thiscall tbb::task::set_ref_count(int)" (?set_ref_count@task@tbb@@QAEXH@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: class tbb::task & __thiscall tbb::internal::allocate_continuation_proxy::allocate(unsigned int)const " (?allocate@allocate_continuation_proxy@internal@tbb@@QBEAAVtask@3@I@Z) referenced in function "void * __cdecl operator new(unsigned int,class tbb::internal::allocate_continuation_proxy const &)" (??2@YAPAXIABVallocate_continuation_proxy@internal@tbb@@@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: void __thiscall tbb::internal::allocate_continuation_proxy::free(class tbb::task &)const " (?free@allocate_continuation_proxy@internal@tbb@@QBEXAAVtask@3@@Z) referenced in function "void __cdecl operator delete(void *,class tbb::internal::allocate_continuation_proxy const &)" (??3@YAXPAXABVallocate_continuation_proxy@internal@tbb@@@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: class tbb::task & __thiscall tbb::internal::allocate_child_proxy::allocate(unsigned int)const " (?allocate@allocate_child_proxy@internal@tbb@@QBEAAVtask@3@I@Z) referenced in function "void * __cdecl operator new(unsigned int,class tbb::internal::allocate_child_proxy const &)" (??2@YAPAXIABVallocate_child_proxy@internal@tbb@@@Z)
1>sub_string_finder.obj : error LNK2019: unresolved external symbol "public: void __thiscall tbb::internal::allocate_child_proxy::free(class tbb::task &)const " (?free@allocate_child_proxy@internal@tbb@@QBEXAAVtask@3@@Z) referenced in function "void __cdecl operator delete(void *,class tbb::internal::allocate_child_proxy const &)" (??3@YAXPAXABVallocate_child_proxy@internal@tbb@@@Z)
1>C:\\Users\\ANDREI~1\\AppData\\Local\\Temp\\tbb_examples\\Debug\\sub_string_finder.exe : fatal error LNK1120: 12 unresolved externals
Also, if you go to the threadingbuildingblocks.org website and drill down into Downloads/Extras, you'll find a set of MSVS plug-ins that can be used to set up the configuration for various versions of TBB.
Also, I just followed Getting Started. I was instructed there to just point the include and lib on the project settings not on the IDE (I don't intent to add it either because using this version for this project only). In my experience doing this would require me to put in the correct .dll of the .libs used to where the compiled binaries will look for it. In this case, it's the same directory as the exe.
-- in short, ia32 works fine but not intel64 --
The operation could not be completed. Unspecified error.
====== Rebuild All: 0 succeeded, 0 failed, 1 skipped =======
