Linking TBB using CMake and tbb_build
M_Z_
I'd like to use CMake, GTest, and TBB for a project on linux, and so far I've been able to build without complaint, but the dynamic linking required by TBB has been a bit of an issue for only one of the libraries.
I'm using the CMake functions invoked like so:
    set(TBB_ROOT_DIR ${CMAKE_CURRENT_SOURCE_DIR}/tbb)
    set(TBB_BUILD_DIR "tbb_build_dir=${CMAKE_ARCHIVE_OUTPUT_DIRECTORY}")
    set(TBB_BUILD_PREFIX "tbb_build_prefix=tbb")
    include(${TBB_ROOT_DIR}/cmake/TBBBuild.cmake)
    tbb_build(TBB_ROOT ${TBB_ROOT_DIR}
              MAKE_ARGS
                  ${TBB_BUILD_DIR}
                  ${TBB_BUILD_PREFIX}
              CONFIG_DIR
              TBB_DIR)
    find_package(TBB REQUIRED)
When running, I get the error:
    error while loading shared libraries: libtbbmalloc_debug.so.2: cannot open shared object file: No such file or directory
After Running `ldd <whatever_test_executable>` I get the following output
    linux-vdso.so.1 =>  (0x00007fff741b9000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fd99a6fd000)
    libtbb_debug.so.2 => /home/mrbzapp/test_proj/build/Builds/lib/tbb_debug/libtbb_debug.so.2 (0x00007fd99a489000)
    libtbbmalloc_proxy_debug.so.2 => /home/mrbzapp/test_proj/build/Builds/lib/tbb_debug/libtbbmalloc_proxy_debug.so.2 (0x00007fd99a285000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fd99a081000)
    libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007fd999dd4000)
    libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fd999a99000)
    libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6 (0x00007fd999887000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fd99967f000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fd9992f7000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fd998fee000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fd998dd7000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fd998a0e000)
    /lib64/ld-linux-x86-64.so.2 (0x000055a935c16000)
    libtbbmalloc_debug.so.2 => not found
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fd9987f2000)
    libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007fd9985c0000)
    libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fd99839e000)
    libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fd998198000)
    libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fd997f92000)
During build I can see that CMake (and TBB's `TBBBuild` function) is adding `/home/mrbzapp/test_proj/build/Builds/lib/tbb_debug/` to the `rpath`, and for most of the linked tbb libs they are using this path, but `libtbbmalloc_debug.so.2` is being left out in the cold and it's bringing the whole thing down with it.
What I find completely baffling is that `libtbbmalloc_debug.so.2` *does* exist, and exists alongside the other TBB libraries that *are* using the rpath set by TBB's functions.
What could I possibly be doing wrong, and what might I have to do in order to make sure all of these libraries are correctly linked at runtime and not just a handful?
Alexey_M_Intel1
Hello, M Z.
I was able to reproduce this problem, thank you for reporting it.
The problem is that libtbbmalloc_proxy_debug.so.2 can't find libtbbmalloc_debug.so.2
As a workaround I can propose you to "source /home/mrbzapp/test_proj/build/Builds/lib/tbb_debug/tbbvars.sh intel64" in your environment and after that execute your application.
We will notify you in this thread when we fix this problem in the Intel TBB library.
