Linking libtbbmalloc_proxy.so in Qt Creator
Oleg_M_4
Hello!
I found this page in the Intel Developer Zone:
https://software.intel.com/ru-ru/node/506097
It sais how to use libtbbmalloc_proxy.so using standart Linux compiler and linker.
Could you, please, help me doing the same using Qt Creator in Linux. What should I write in the pro-file to achieve the same result?
Thanks in advance.
