Macro'__TBB_compiler_fence' is 'nop-ed' if TBB is compiled withIntel C/C++ compiler.
Header file: windows_ia32.h
#if __INTEL_COMPILER
#define __TBB_compiler_fence() __asm { __asm nop }
#elif _MSC_VER >= 1300
extern "C" void _ReadWriteBarrier();
#pragma intrinsic( _ReadWriteBarrier )
#define __TBB_compiler_fence() _ReadWriteBarrier()
#else
Could somebody explainwhyisthe macro'nop-ed'?
like NOP.
Quote:
It is important to understand that _ReadWriteBarrier does not insert any additional instructions, and it does not prevent the CPU from rearranging reads and writes-it only prevents the compiler from rearranging them.
http://msdn.microsoft.com/en-us/library/ee418650%28v=vs.85%29.aspx
like NOP.
Interesting because my local version of MSDN installed with the Visual Studio 2005 doesn't have that
statement. I'll take a look at what codes will be compiled by Visual Studios 2005, 2008 and 2010 for a
simple Test-Case.
like NOP.
[SergeyK] Yes, I did look.
[SergeyK] Yes, I confirm this. It rather "ignores" some instructions that could create an Access
Violation.
It looks like avery tricky and unreliable feature in terms of portability between different
platforms and C/C++ compilers. MS C/C++ compiler ( Visual Studio 2005 )has NOT generated a 'nop'
assembler instruction. Also, that feature is NOT available if ALL optimizations are disabled.
I wouldn't rely on '_ReadWriteBarrier' intrinsic function in case of a highly portable C/C++ library
because it doesn't force a software developer to fix a possible problem in a code that could create
an Access Violation, like:
RTint *pData = RTnull;
g_iVariable = *pData;
g_iVariable = 7;
I understand that software developers on the TBB project could have some different considerations
regarding the '_ReadWriteBarrier' intrinsic function.
Two Test-Cases are provided and take a look if you're interested:
Note: I tested with Visual Studio 2005
#include
RTint g_iVariable = 0; // Must be Declared as global!
Test-Case 1 - _USE_READWRITEBARRIER is NOT defined
// #define _USE_READWRITEBARRIER
// Test-Case 1
RTint *pData = RTnull; // Instruction is NOT generated
g_iVariable = *pData; // Instruction is NOT generated
#if defined ( _USE_READWRITEBARRIER )
#endif
g_iVariable = 7;
0040189F mov dword ptr [g_iVariable (5F29C4h)], 7 // Instruction is generated
Test-Case 2 - _USE_READWRITEBARRIER is defined
// Test-Case 2
0040189C xor eax, eax
0040189E mov eax, dword ptr [eax]// Unhandled exception error ( see below )
004018A0 add esp, 0Ch
004018A3 mov dword ptr [g_iVariable (5F29C4h)], eax
#endif
g_iVariable = 7;
004018A8 mov dword ptr [g_iVariable (5F29C4h)], 7
Unhandled exception error:
Unhandled exception at 0x0040189e in ScaLibTestAppD.exe: 0xC0000005: Access violation
reading location 0x00000000.
Some of my C/C++ compiler command line options are as follows:
/O2 /GF /Gm /EHsc /MTd /openmp /W4 /nologo /c /Zi /TP /errorReport:prompt
Optimization for Speed
The example further illustrates why nonoptimised as well as optimised builds should always be tested.
