Making my own hash array.
kio_marv
I'm trying to use tbb::concurrent_hash_map to implement a wrapper class in order to use it in my programs. So far, I have done this:
[cpp]#include "tbb/concurrent_hash_map.h" #include template struct HashCompare { static size_t hash( const K& key ) { return tbb::tbb_hasher(key); } static size_t hash( K* key ) { return reinterpret_cast( key/sizeof(key) ); } static bool equal( const K& key1, const K& key2 ) { return ( key1 == key2 ); } }; template class HashArray { private: static unsigned int initial_hash_size; tbb::concurrent_hash_map > h; const HashArray& operator=( const HashArray& S ); public: HashArray(): h(initial_hash_size) {} HashArray( const HashArray& S ) : h( S.h ) {} ~HashArray() {} const E& operator[]( const K& key ) const{ typename tbb::concurrent_hash_map >::const_accessor a; if ( !h.find(a,key) ) { h.insert(a,key); } return a->second; } E& operator[](const K& key){ typename tbb::concurrent_hash_map >::accessor a; if ( !h.find(a,key) ) { h.insert(a,key); } return a->second; } int IsDefined(const K key) const { if (h.count(key)!=0) return 1; else return 0; } void UnDefine(const K key) { typename tbb::concurrent_hash_map >::accessor a; if( h.find(a,key) ) { h.erase(a); } } void GatherStats(std::ostream& O) const { typename tbb::concurrent_hash_map >::const_iterator it( h.begin() ); while ( it != h.end() ) { O << ((*it).second).size(); ++it; } } void Clear(void) { h.clear(); } void Resize(void) { h.clear(); } }; template unsigned int HashArray::initial_hash_size=1000;[/cpp] I have tested this code in a simple program and it works well. However, I would like to hear what you think about it. What I fear is that it's bad code and it might fail in a large program.
Thanks!
kio_marv
Hello? Anyone?
Anton_M_Intel
Sorry, it is completely wrong approach. The bad code is marked in comments below
Quotingkio.marv
I'm trying to usetbb::concurrent_hash_mapto implement a wrapper class in order to use it in my programs.
Usually it is bad idea to wrap concurrent_hash_map as an STL-like serial container. It leads to fatal threading errors.
    static size_t hash(
      K* key
Why a pointer? shouldn't it be a reference instead?
Are you aware that the actual key is a pointer to a key value? E.g. if you have two instances of the same value, they will be considered as different keys.
    static bool equal(
        const K& key1,
        const K& key2
However, here, you are comparing the values of keys, not pointers.
          const K& key
      ) const{
            h.insert(a,key);
        return a->second;
find() is excessive as insert does the same job. And it is not thread-safe as you return the reference without protection by accessor while using erase().
Concurrent modifications are also not protected.
          h.erase(a);
Well, it is the right way to prevent other threads from working with a concurrently erased instance. But I guess it was not the intention.. because without correctly used accessors, find() is excessive here as well.
You are right.
SergeyKostrov
Valued Contributor II
Hi everybody,
Quoting kio.marv
...I have tested this code in a simple program and it works well. However, I would like to hear what you think about it. What I fear is that it's bad code and it might fail in a large program...
Here are a couple of questions:
- Did you try to evaluateperformance ofyourcodes and tocomparewith performance ofHash classesofSTL or Boost libraries?
- Did you do a Stress Testing with as larger as possibledata sets?
- Could you submit a Test-Case?
Sergey
