MinGW and TBB installation
nath02
Hi everybody !
I really need some help, here's my problem : I have to work on a project in c++ and I have to parallelise it.
I have un computer with 8 CPU's (Windows 7)and I have to work with Eclipse and MinGW.
BUT how can I install TBB with MinGW ? I mean, I read a lot of articles and documentations on Windows installation but, that's usually talking about Visual Studio and I must not use that.
How could I do tobuild TBB? Do you have any solution ? I'm completly lost and quite tired. I have already lost a lot of time on this installation and I'm quite annoyed...
If someone had succeeded in that kind of installation, could you explain to me in details how you did so ?
Really, thanks in advance, I really need your help.
Thanks again.
Here's my compilator configuration :gcc 3.4.5
Vladimir_P_1234567890
would the command
cmd /c"cmd /c mkdir "windows_ia32_gcc_mingw_release""
work on your machine and create the folder?
--Vladimir
nath02
Thank you !
@Vladimir : I can't answer you now; actually, my motherboard is down, so I have to wait until tomorrow to get my computer back. I thought to install Win XP 64bits in place of Windows 7, maybe I'll have so many problems... Otherwise, I'll try your suggestion, and I'll tell you the result !
@Alexey Thank you! I'm looking forward to try it. I don't have the time at the moment to study it (I'm at school), but of course, I'll ask if I don't understand something.
Thank you, both of you !
Actually, here is the structure of my loops :
ClassFunct::ClassFunct() {
readFile();
// fill the matrix
int int_amount = int_vect.size();
for (int i=0; i
for (int j=i+1; j
//my code
And, I'm quite embarassed by the initialisation of second index : j : i+1
Does it create a dependence between the two loops ?
It is appropriated to use a parallel_for on the first loop ? Won't my data be corrupted ?
What do you think ?
Thanks !
nath02
Actually, I don't see what's the my_A variable ? What's its value ?
Denis_Bolshakov
my_A is the pointer on int.
It's a class member.
Denis_Bolshakov
[bash]#include  //has declaration of task_scheduler_init
#include         //has declaration of parallel_for and blocked_range
class Functor
public:
    Functor(int** matrix, size_t amount) : m_matrix(matrix), m_amount(amount){}
    void operator()(const tbb::blocked_range& range) const
        for (size_t i = range.begin(), end = range.end(); i != end; ++i)
            for (size_t j = i + 1; j < m_amount; ++j)
                int& elementFromMatrix = matrix;
                //please locate your code here
private:
    int** m_matrix;
    size_t m_amount;
void doMyTaskParallel()
    size_t amount = //please init here
    int** matrix = //please init here
    tbb::parallel_for(tbb::blocked_range(0, amount), Functor(matrix, amount), tbb::auto_partitioner());
int main()
    tbb::task_scheduler_init init;
    doMyTaskParallel();
    return 0;
}[/bash]
wesleygriffin
To follow up on this and perhaps provide a solution, as I'm attempting the same thing:
OS: Windows 7 x64
MinGW just installed, from MinGW-5.1.6.exe and MSYS-1.0.11.exe
I have upgraded the compiler:
C:\Users\wgriffin\Active\tbb>gcc -v
Using built-in specs.
Target: mingw32
Configured with: ../gcc-4.4.0/configure --enable-languages=c,ada,c++,fortran,java,objc,obj-c++ --disable-sjlj-exceptions --enable-shared --enable-libgcj --enable-libgomp --with-dwarf2 --disable-win32-registry --enable-libstdcxx-debug --enable-version-specific-runtime-libs --prefix=/mingw --with-gmp=/mingw/src/gmp/root--with-mpfr=/mingw/src/mpfr/root --build=mingw32
Thread model: win32
gcc version 4.4.0 (GCC)
I've tried both mingw32-make (which -v reports as GNU Make 3.81) and the gnuwin32 make fromhttp://gnuwin32.sourceforge.net/packages/make.htm (also GNU Make 3.81) with identical results.
When I run:
C:\Users\wgriffin\Active\tbb>C:/msys/1.0/bin/sh.exe -c "cmd /c mkdir "windows_ia32_gcc_mingw_release""
I get a brand new command shell:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\wgriffin\Active\tbb>exit
When I run:
C:\Users\wgriffin\Active\tbb>cmd /c "cmd /c mkdir"windows_ia32_gcc_mingw_release""
It creates the directory as C:\windows_ia32_gcc_mingw_release
If I rename C:\MSYS\1.0\bin\sh.exe, then tbb builds fine (note I didn't try any of the other targets).
C:\Users\wgriffin\Active\tbb>mingw32-make compiler=gcc arch=ia32 runtime=mingw tbb
but without specifying the arch/runtime:
C:\Users\wgriffin\Active\tbb>mingw32-make tbb
cd ".\\build\\windows_unknown_cl_unknown_release" && cmd /C "..\..\build\generate_tbbvars.bat" windows_unknown_cl_unknown_release
cd ".\\build\\windows_unknown_cl_unknown_debug" && cmd /C "..\..\build\generate_tbbvars.bat" windows_unknown_cl_unknown_debug
mingw32-make -C ".\\build\\windows_unknown_cl_unknown_debug" -r -f ../../build/Makefile.tbb cfg=debug tbb_root=../..
mingw32-make[1]: Entering directory `C:/Users/wgriffin/Active/tbb/build/windows_unknown_cl_unknown_debug'
../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=unknown compiler=cl os=windows runtime=unknown
cl /nologo /c /MDd /Od /Ob0 /Zi /EHsc /GR /Zc:forScope /Zc:wchar_t /DTBB_USE_DEBUG /DDO_ITT_NOTIFY /DUSE_WINTHREAD /D_CRT_SECURE_NO_DEPRECATE /D_WIN32_WINNT=0x0400 /D__TBB_BUILD=1 /W4 /I../../src /I../../src/rml/include /I../../include../../src/tbb/concurrent_hash_map.cpp
process_begin: CreateProcess(NULL, cl /nologo /c /MDd /Od /Ob0 /Zi /EHsc /GR /Zc:forScope /Zc:wchar_t /DTBB_USE_DEBUG /DDO_ITT_NOTIFY /DUSE_WINTHREAD /D_CRT_SECURE_NO_DEPRECATE /D_WIN32_WINNT=0x0400 /D__TBB_BUILD=1 /W4 /I../../src /I../../src/rml/include /I../../include ../../src/tbb/concurrent_hash_map.cpp, ...) failed.
make (e=2): The system cannot find the file specified.
mingw32-make[1]: *** [concurrent_hash_map.obj] Error 2
mingw32-make[1]: Leaving directory `C:/Users/wgriffin/Active/tbb/build/windows_unknown_cl_unknown_debug'
mingw32-make: *** [tbb] Error 2
Wes
Alexey-Kukanov
You have to specify compiler=gcc to use TBB with MinGW.
alekcac
Is there any way to compile tbb under mingw-w64?
Alexander
Alexey-Kukanov
No we did not work on support for MinGW-w64. And I do not remember anybody asking for it before.
Wanna step in and implement such support based on what we have for MinGW32? :)
mazay0gmail_com
Well, I don't know what could be wrong with running mingw32-make on Windows 7. I tried it on my workstation, all went just fine. I don't remember if you tried another make utility - if yes, was it any different?
But anyway you should not be blocked by that, as you don't have to recompile TBB on exactly the same machine where you plan to run your app. Just copy the binaries to that machine, set up the environment properly, and you should be fine.
I tried to make TBB on Windows 7 from package tbb30_20100406oss_src.tgz with mingw32-make (GNU Make 3.81)
with this command:
mingw32-make.exe compiler=gcc arch=ia32 runtime=mingw
It just hangs and prints nothing. According to Process Explorer the procedure hangs on attempt to execute
c:\Windows\system32\cmd.exe c:/ mkdir .\build\windows_ia32_gcc_mingw_release
It is definitely wrong command because of c:/ parameter. I investigated the issue a bit and it seems to be the problem in $(shell ...) function. It transforms "cmd /c mkdir" to "c:\Windows\system32\cmd.exe c:/ mkdir" by some reason. I tried to remove "cmd /c" from makefile's but got another errors.
Same issue on Windows 2003.
Solved!!! Just remove sh.exe from all paths in %PATH%.
bradleygibson
I found this thread as I was searching for the same thing (mingw-w64 support)... Too bad.
Roughly speaking, how big a job is that (assuming strong kung fu)?
zogmachine
Hi, I'm new.
I have compiled the library.
I'm on windows and trying to setup this in eclipse cdt.
how exactly do i set cpath and library_path?(I did it via Properties>Environment>Add (i know this isnt eclipse forum))
visual aid: http://postimage.org/image/gav5aivaz/
have you added tbb.dll to your link command line?
--Vladimir
palodequeso
I know this thread is older now but I'm still hoping someone can point me in the right direction. I'm hoping to compile tbb with mingw32 as well. As far as I can tell everything built just fine however I'm not seeing any .a or .so files get generated. Is this expected? For the visual c version there's a .lib file and in linux there is a library as well, but of course I just installed that with the package manager.
hello, for MinGW you need to link with dll:)
--Vladimir
Simon_L_1
I'm glad this topic was resurrected recently as it saves me apologising for doing so :)
I'm trying to compile the latest stable release (tbb42_20131003oss) under mingw-w64 with MSYS.
My mingw is from here https://sourceforge.net/projects/mingwbuilds/files/host-windows/releases/4.8.1/64-bit/threads-win32/seh/ - the rev5 version.
My MSYS is from here https://sourceforge.net/projects/mingwbuilds/files/external-binary-packages/ - the rev13 package.
My build command for TBB is "make arch=ia32 compiler=gcc runtime=mingw SHELL=/bin/sh"
I've run into the exact same issue as others on this thread with the "mkdir" target - where there should be a /c on the resulting cmd command line, this is somehow translated to c:/, causing a hang.
I fixed this by simply removing the mkdir commands and making the directories manually.
Now my error is:
make -C ".\\build\\windows_ia32_gcc_mingw64_debug"  -r -f ../../build/Makefile.t
bb cfg=debug
'\"cscript /nologo /E:jscript ../../build/detect.js /minversion gcc 4.4\""' is not recognized as an internal or external command, operable program or batch file.
make[1]: Entering directory `/c/Users/user/dev/tbb42_20131003oss/build/windows_ia32_gcc_mingw64_debug'
../../build/Makefile.tbb:39: CONFIG: cfg=debug arch=ia32 compiler=gcc target=windows runtime=mingw64
g++ -o concurrent_queue.o -c -MMD -g -O0 -DTBB_USE_DEBUG -DUSE_WINTHREAD -D_WIN32_WINNT=0x0502 -DMINGW_HAS_SECURE_API=1 -D__MSVCRT_VERSION__=0x0700 -msse -mthreads -m32 -march=i686  -D__TBB_BUILD=1 -Wall -Wno-parentheses -Wno-uninitialized   -I../../src -I../../src/rml/include -I../../include ../../src/tbb/concurrent_queue.cpp
'ml' is not recognized as an internal or external command, operable program or batch file.
../../build/common_rules.inc:85: recipe for target `concurrent_queue.o' failed
make[1]: *** [concurrent_queue.o] Error 1
make[1]: Leaving directory `/c/Users/user/dev/tbb42_20131003oss/build/windows_ia32_gcc_mingw64_debug'
Makefile:40: recipe for target `tbb' failed
I note the failure to execute detect.js, which is similar to the failure to execute the same thing if you don't disable auto-detection of the runtime by specifying it explicitly.
I also note the user above who said his problem was solved by ensuring sh was not anywhere in %PATH% - I don't believe it is for me.
One other thing, if I run the g++ command in isolation in the appropriate directory, it works fine, so hopefully it's just the detect.js call which needs fixing.
Simon_L_1
OK I have a successful build. I was taking a slightly wrong approach.
Instead of building under MSYS, I did the following:
1) Ensure c:\mingw-w64 (or whatever) is part of %PATH%
2) Use PowerShell!!!! Not cmd.exe, not sh.exe, not bash.exe. PowerShell. As a primarily Linux developer this was completely non-obvious to me.
3) Run mingw32-make.exe compiler=gcc
I can't find instructions on doing this anywhere - perhaps a good thing to add to the current docs?
I used to build there in this way under cmd.exe. I'm not sure where it still works
mingw32-make.exe compiler=gcc SHELL=cmd.exe
--Vladimir
