I wonder what is the status of mingw support. How to turn it on if it exists? If it does not. What is planned or not?
It should work with 32-bit MinGW. Getthe open source release of TBB 2.2. Provided that MinGW environment is properly set up,build TBB withgmake compiler=gcc.Then you should have the TBB runtime DLLs that can be used with a program built by MinGW.
