Nested For Loop: blocked_range 1D or 2D
akhal
Hej
I am kinda newbie with Intel TBB and trying out parallelizing a problem which worked well with OpenMP but doesnt show speed up with TBB though looping are independent. I thought maybe 2D blocked_range might help, though it shows speedup but wrong results of calculation. My codes are as follows:
/*-----Serial Version-----*/
for(k=0; k {
for(i=k+1; i {
s = s/s;
for(j=k+1; j s -= s*s;
/*OpenMP version (which shows considerable speedup) */
#pragma omp parallel default(shared) private(k)
for(k=0; k {
#pragma omp for private(i,j) schedule(static)
for(i=k+1; i {
a = a/a;
for(j=k+1; j a1 = a1 - a1*a1;
/* TBB version (1D blocked_range) */
task_scheduler_init TBBinit(nthreads);
for(int k=0; k parallel_for(blocked_range(k, size, (size-k)/nthreads), my_class(a2));
/* setting grainsize to that values reduced time but still its multiple of serial exection time:( */
class my_class
double** my_a;
public:
my_class(a[size][size]):my_a(a){}
void operator() (const blocked_range& r) const
double** a2 = my_a;
int k = r.begin();
for(int i=k+1; i!=size; i++)
a2 = a2/a2;
for(j=k+1; j!=size; j++)
a2 = a2 - a2*a2;
}; //This 1-D gives so poor performance
/*----- I tried 2-D range as follows-------*/
for(int k=0; k parallel_for(blocked_range2d(k,size,(size-k)/nthreads,k,size,(size-k)/nthreads), my_class2d(a3));
//Class body
class my_class2d
double** my_a;
public:
my_class2d(a[size][size]):my_a(a){}
void operator() (const blocked_range2d& r) const
double** a3 = my_a;
int k = r.rows().begin();
int end = r.rows().end(); //or r.cols().end()
for(int i=k+1; i!=end; i++)
a3 = a3/a3;
for(j=k+1; j!=end; j++)
a3 = a3 - a3*a3;
//But this 2D attempt gives wrong results
Is this structure even parallelizable with TBB, if yes then with 1D range or with 2D range, because my 1D range example gives correct results but its too far slow than even serial, and 2D is fast but wrong results. Any help?
Kirill_R_Intel
This post is duplicate of http://software.intel.com/en-us/forums/showthread.php?t=83935. Lets continue discussion there.
