Optimizing a TBB pipeline
Sensei_S_
Dear all,
I'm currently using a parallel pipeline with I/O bounded filters. Let me remind you my project, if you can bear with me.
A serial filter reads a string, a parallel filter transforms a string, and a serial filter writes back. In order to have better performance, or so I thought, the writer and transformers threads won't communicate directly. Instead, the transformer filter writes to a concurrent queue, and the writer pops from that.
Now I've launched my program setting in the main a number of threads, in my case tbb::task_scheduler_init init(6), however, in Xcode I see that I have only two threads on. The pipeline, moreover, is slow. I expected it to be so, since I'm using a transformer that is actually an optimizer with complexity O(n^3), but I think I'm doing something really wrong here.
So now, how can I profile my program in order to see what is slowing down the pipeline? I'd really like to optimize it at the best I can do.
I think I could use a queue also from reader to transformer threads, if this could help. Or the problem could lie in the writer, but I don't really know how I can see if this is the case...
Any hints would be really appreciated!
Cheers!
jimdempseyatthecove
Black Belt
Here is a sample program from an older version of TBB
TBB parallel_pipeline
// Filter that writes each buffer to a file.
class MyOutputFilter: public tbb::filter
FILE* my_output_file;
public:
MyOutputFilter( FILE* output_file );
/*override*/void* operator()( void* item );
MyOutputFilter::MyOutputFilter( FILE* output_file ) :
tbb::filter(/*is_serial=*/true),
my_output_file(output_file)
void* MyOutputFilter::operator()( void* item )
MyBuffer& b = *static_cast<MyBuffer*>(item);
fwrite( b.begin(), 1, b.size(), my_output_file );
return NULL;
// Filter that changes the first letter of each word
// from lower case to upper case.
class MyTransformFilter: public tbb::filter
public:
MyTransformFilter();
MyTransformFilter::MyTransformFilter() :
tbb::filter(/*serial=*/false)
/*override*/void* MyTransformFilter::operator()( void* item )
bool prev_char_is_space = b.begin()[-1]==' ';
for( char* s=b.begin(); s!=b.end(); ++s )
if( prev_char_is_space && islower(*s) )
*s = toupper(*s);
prev_char_is_space = isspace(*s);
return &b;
class MyInputFilter: public tbb::filter
public:
static const size_t n_buffer = 4;
MyInputFilter( FILE* input_file_ );
private:
FILE* input_file;
size_t next_buffer;
char last_char_of_previous_buffer;
MyBuffer buffer[n_buffer];
/*override*/ void* operator()(void*);
MyInputFilter::MyInputFilter( FILE* input_file_ ) :
next_buffer(0),
input_file(input_file_),
last_char_of_previous_buffer(' ')
void* MyInputFilter::operator()(void*)
MyBuffer& b = buffer[next_buffer];
next_buffer = (next_buffer+1) % n_buffer;
size_t n = fread( b.begin(), 1, b.max_size(), input_file );
if( !n )
// end of file
return NULL;
else
b.begin()[-1] = last_char_of_previous_buffer;
last_char_of_previous_buffer = b.begin()[n-1];
b.set_end( b.begin()+n );
return &b;
// Create the pipeline
tbb::pipeline pipeline;
// Create file-reading writing stage
MyInputFilter input_filter( input_file );
// and add it to the pipeline
pipeline.add_filter( input_filter );
// Create capitalization stage
MyTransformFilter transform_filter;
pipeline.add_filter( transform_filter );
// Create file-writing stage
MyOutputFilter output_filter( output_file );
pipeline.add_filter( output_filter );
// Run the pipeline
pipeline.run( MyInputFilter::n_buffer );
// Remove filters from pipeline before they are implicitly destroyed.
Jim Dempsey
robert-reed
Valued Contributor II
I have a blog series that is pretty old now (and thus may be a little decrepit) but is all about using Intel TBB pipelines to overlap processing with serial I/O  so might still have some relevance to your current problem.  It starts here:
https://software.intel.com/en-us/blogs/2007/08/23/overlapping-io-and-processing-in-a-pipeline
