2481 Discussions
Parallel implementation for tree traversal as the best practice
Nishikawa__Mitsuru
I understand TBB is designed to be composable threading library, which enable parallelism in nested, or recursive, algorithms.
By taking advantage of it, I would like to make tree traversal algorithm parallel for ray tracing, or intersection tests. (needed to query many objects, so queries are made parallel)
As the best knowledge to me, the easiest way to realize it is to nest tbb::parallel_for. But, I am afraid that a lot of creation of tasks, which is produced in tbb::parallel_for in recursive call, degrade the performance.
I would appreciate it if you could tell me the best practices, or sample codes, for such a manner, without performance loss.
Kind regards
Nishikawa__Mitsuru
I noticed that cutoff, which is limitation number of task, is used to avoid overhead as written in an example of quick sort in "Pro TBB" Chapter 2 PP.41.
<https://link.springer.com/book/10.1007/978-1-4842-4398-5>
I also consider such a limit in my tree traversal algorithm.
Kind regards
IntelSupport
Community Manager
Hello. I have started an investigation.
IntelSupport
Community Manager
Hello. TBB is composable so it is going to be aware of how many threads it has created. So this should not degrade the performance.
IntelSupport
Community Manager
This issue has been resolved and support will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
